Old 10-27-2013, 01:05 PM
XTRMEASURES's Avatar
XTRMEASURES XTRMEASURES is offline
Default question about trailing arm on a torque arm suspension
Does the trailing arm have to be parallel like in a 4-link/bar setup? Or does it matter as much? Thanks
A man that's motivated will find a way.
PROJECT'S
1984 GMC swb truck
1972 Camaro
2013 GMC truck
Old 10-27-2013, 01:40 PM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
My 2 cents. With a Torque Arm style rear suspension, the primary rear end locator in the Torque Arm itself. Articulation, CG and anti-squat will primarily be controlled by the location of the Torque Arm. With the added rear link arms, they can be mounted in various locations as long as during ride height they pivot in correlation with the Torque Arm in a manner that no binding is present.
So, in theory those lower rear link arms typically will be parallel to the ground to reduce rear steer, but can be angle inward toward the front frame location and outward to the rear axel mounting locations. However, I would try to locate them as wide as possible at the axel and then point them toward the front pivot point of the Torque arm.
The best way to determine if your deviated set up works is to actually mock it up and motion the suspension through it's typical cycle for verification of the correct articulation.
Old 10-27-2013, 03:20 PM
Thank you sir, could you direct me to pics or a link to the mention description.
PROJECT'S
1984 GMC swb truck
1972 Camaro
2013 GMC truck
