Old 04-29-2006, 09:04 PM
Mike Hall's Avatar
Mike Hall Mike Hall is offline
Default T56 mid shifter?
I could have sworn I saw a Mid shifter setup for a T56. Could some let me know if i was dreaming or if there is such a thing. I did a google search without any results for a T56 but I did find mid shifter kits for the TKO.
Mike
Old 05-01-2006, 10:47 AM
rocketman's Avatar
t-56's only have one shifter location,on the tailshaft.
Old 05-01-2006, 01:04 PM
Mike Hall's Avatar
Well that sucks. I guess it was the TKO that had the mid shifter option. Im going to be moving the engine back a good 8" in my 66 nova and the shifter will be to far back to be easy to use.
Mike
Old 05-01-2006, 01:20 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
I understand McLeod has a mid-position shifter that (IIRC) requires replacement (or modification) of the internal shift rail.
Old 05-02-2006, 03:15 PM
JamesJ JamesJ is offline
you can move the shifter to the mid location. It takes seme work but we have done it many times
James J.
Old 05-02-2006, 03:47 PM
Steve1968LS2's Avatar
Mike
The McLeod shifter can mount there.. in that location there is a modification required and it's explained in the McLeod litt..
