Old 01-03-2014, 03:48 PM
Keithq68 Keithq68 is offline
Default 2014 Z28 differential part #, Mark Stielow?
Im building a 69 Camaro and I'm considering using the differential from the new Z28. It's a Torsen diff with 3.91 gears.
I had considered the ZL1 diff but i think the Torsen diff lends itself to my application better than the clutch type LSD in the ZL1.
I checked with the dealer and he needs a VIN number to get me a part number, since its not available until spring i can't get that.
I realize the part is probably not available yet but they may have pricing so i can decide if i want to wait or just buy the ZL1 diff.
Any help would be appreciated
Thanks.
Keith Quinn.
Old 01-03-2014, 09:39 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Thanks.
Keith Quinn.
Mark is on vacation, but you don't need a vin number. You will have to wait till the part is available, but you can contact this company.
http://www.newgmparts.com
This company will ask for vin, but all the vin does is make sure that you order the correct part number. You just tell them that you don't have the Vin Number for the car. Although, the sales person can look up the part number for you or use the Newgmparts website in the future. (That company is cheaper than your dealer).
Jeff
Old 01-03-2014, 11:07 PM
Stielow's Avatar
Stielow Stielow is offline
Thanks.
Keith Quinn.
Are you adding a IRS to a Camaro? If not why do you want this diff? If you want a Torsen style diff for a solid axle (Ford 9 inch or 12 Bolt) I think some are out there.
If you want the Z/28 diff it will be available through GM Performance Parts this spring.
Mark
Old 01-03-2014, 11:25 PM
camcojb camcojb is online now
Thanks.
Keith Quinn.
Mark
And there 'ya go. Thanks Mark, hope Bali is fun.
Old 01-04-2014, 07:02 AM
Thanks guys.
I have installed a C6 IRS in my 69, i originally planned on using the Dutchman aluminum IRS center section with an aluminum drop out and a quaife differential.
This setup ends up being a little over $4000.
I was looking at the ZL1 differential because it was reasonably priced and was up to the task as far as durability. Then I read about the Z28 differential and prefer the focus on road racing rather than 1/4 mile like the ZL1.
That is the focus of my car. I should be around 3100lbs and the same or slightly less HP as the Z28.
I was wondering if the price was set now so i could decide if its worth waiting or if i should just go with one of the other options. Is there a way to check pricing now?
The other diff i was considering is the 1LE with the 3.91 gear. I think that uses a standard clutch type LSD though.
Thanks for the quick replies and for answering while on vacation Mark.
Keith Quinn.
Old 01-06-2014, 08:46 PM
Operations's Avatar
Operations Operations is offline
I'm interested too!
Old 01-07-2014, 07:26 AM
Bill Howell Bill Howell is offline
Site Sponsor
http://www.gmhightechperformance.com..._irs_solution/
Here is another possible solution for you. Jeff Lee and his father are doing these now. I know they have been covered in a couple magazines. You may want to check with them for fitment verification.
Bill Howell
www.americanstreetcarseries.com
Old 01-07-2014, 09:05 AM
Default Hamnerhead
Thanks Bill.
I did look at the Hammerhead also but only saw pricing for kits.
I would just need the center section.
I did call and leave a message asking for pricing without axles.
If seems like a very pricey setup though.
The GM parts are priced very reasonably and I think they will take the abuse that it will see in my application.
Keith Quinn.
Old 01-07-2014, 11:39 AM
Site Sponsor
OK, I just knew these guys had IRS parts.
Bill Howell
Old 01-07-2014, 12:13 PM
dontlifttoshift's Avatar
I'm sure you have seen it, but if not have you looked at Strange's S60 IRS center section?
Donny
