Old 01-06-2014, 03:51 PM
Viperlover's Avatar
Viperlover Viperlover is offline
Default Battery draw and buzzing coming from behind glove box
I believe this has something to do with the heater fan because it started after I hooked it back up. This is in my 71 Monte Carlo.
So the battery is completely flat. When I tried charging it tonight I heard a buzzing coming from the car. I could also feel a faint vibration on the passenger side of the firewall.
After investigating a bit I found that the buzzing is coming from some box with wires coming from the bottom that is right behind the glove box. The buzzing got louder as I opened the door and activated the interior light, but it had a bit of delay to it. When I pushed the button in to turn the light off it took a second to quiet down, but still buzzes.
Has anyone ran into this before with a Chevelle or any other old GM vehicle?
I would like to get this figured out soon so I can take this freshly T56 swapped Monte out and rip some ass.
Old 01-10-2014, 09:28 AM
Viperlover's Avatar
I disconnected the ground for the heater fan switch, it still buzzes.
I pulled out the two metal pieces in the steering column by the key, it still buzzes.
This is beyond aggravating.
Old 01-10-2014, 09:47 AM
OBeer-WAN-Kenobi's Avatar
Heater resistor?
Blower relay?
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 01-10-2014, 04:26 PM
Che70velle's Avatar
This is without the key in the ignition switch?
Thanks Dad!!
Old 01-12-2014, 01:08 PM
You may have a dead short IN the battery --- but because it's flat there's just some voltage without any amperage. I would disconnect the battery and take it and run a load test etc on it. Sometimes a battery can sulfate and the sulfate builds up in the bottom of the battery until it shorts out the plates.
Old 01-13-2014, 07:38 PM
Viperlover's Avatar
Didn't matter if the key was in or out. I believe it may be the blower relay gone bad. I pulled the plug out to stop the buzzing and my fan still works with a switch that was wired in years ago.
It no longer kills the battery and everything works...
Finally got to take the Monte out with the 6 speed. Great easy clutch pedal and the pro 5.0 shifter is sweet. No more burning up the old TH350.
