Old 05-09-2006, 05:03 AM
novaz novaz is offline
Default Shock Angle
I am using Strange double adjustables on the rear of my 72 Nova
traction bars up against the stops and multi leaf springs it hooks up really well .
my question is will I gain any improvement by running the shocks in a vertical position as opposed to the 78* they are at now, I installed a camaro type rear shock mounting bar behind the axle and the shocks lined up perfectly with the lower mount points on my Ford 9".
Old 05-10-2006, 06:22 AM
astroracer astroracer is offline
This isn't anything that the adjustability of the shocks shouldn't be able to handle. As you tip a shock out of "vertical" you do lose some performance but 12* isn't enough to degrade performance to the point that you can't adjust them to compensate. If it works now, don't "fix" it...
Mark
"Bad Ast" Astro Van Pro-Touring Project.... Heat, beat, file to fit, paint to match...
Old 05-11-2006, 05:03 AM
Default shock angle
Hey Mark
Thanks for your input
