Old 01-19-2014, 08:35 PM
408sbfmustang 408sbfmustang is offline
Default Mustang with a Ladder bar suspension
Just wanting to return my 1965 Mustang back into a street car since I have had it for sale awhile now.With a ladder bar rear end how would it corner on the street?Or should I just change out the rear for a torque arm or 4 link?
Here is the current set up.
408w,14:00 to 1 naturally-aspirated, AFR 225 CNC cyl heads,Jesel shaft rocker,All steel internals.
Performance-Automatic Super Comp Transmissions case file 10inch converter,P.S.T. Aluminum drive shaft
Currie narrowed 9in rear end,Strange case and spool,4.30 gears
Mustang II front suspension,tubular control arms,QA1 R adjustable coilovers,Wilwood brakes
Applied Racing Pro Ladder bar with QA1 adjustable shocks,mini tubed
Weld Magnums 15 x 8 (28x10x15)M.T.
Car is painted Forest green with black int.4in cowl custom fiberglass hood,Lexan front and rear windows,RaceData I50 dash,MSD digital 6 ign,Kirkey seats with cloth covers, 8 point moly(cage needs to be re cert),10g aluminum fuel cell,Mallory 140 fuel pump,Registered with black plates
Old 01-20-2014, 08:09 AM
Ron Sutton's Avatar
For any car to handle well in the corners the rear suspension needs to articulate (body & rear end housing angle difference). Ladder bars bind with small roll angles, which is very bad for cornering.
If you go to this thread and read post #3, you'll find the differences in the various types of rear suspensions for handling.
Best wishes.
Ron Sutton Race Technology
Old 01-20-2014, 04:13 PM
preston preston is offline
not to mention a spool, 4.30 gears, and 14:1.
Old 01-20-2014, 05:42 PM
That motor will be replaced by a 5.4 modular and 5 speed trans.I going to be changing out the spool for a limited slip.
Old 01-20-2014, 07:26 PM
no go nova's Avatar
no go nova no go nova is offline
Why not just do a custom style torque arm setup since you already have the mounting points for the ladder bar already set up. Also add a front sway bar to help with body roll. And will the 5.4 be N/A, turbo or supercharged?
Old 01-20-2014, 09:29 PM
I thought about using the ladder bar cross member to mount a torque arm.The 5.4 is out of a 99 E250 but needs a new crank.Thought about doing a turbo setup.There is so much that needs to be changed that would love to just sell it and build a new car.
Old 01-21-2014, 06:42 AM
Anything other than that is just peein' in the wind. You could give the car away and be money ahead by the time you change everything about the car. Sell it -- make a plan - buy or build new what you want this time around.
