Old 05-10-2006, 09:27 AM
Diognes56's Avatar
Diognes56 Diognes56 is offline
Default New 6spd manual
Seems that there is a new 6spd manual coming up to go along with the 6spd auto. It will be interesting to see what it can hold up to .
http://media.gm.com/division/2004_pr...ary_manual.pdf
David
Old 05-10-2006, 09:44 AM
Steve1968LS2's Avatar
Weird looking with no shifter on top..
I wonder if it's a Tremec unit??
Old 05-10-2006, 12:18 PM
Diognes56's Avatar
I don't think Tremec has anything to do with it, it is supposed to share many components with the 6L80E and other 6spd autos .
David
Old 06-16-2006, 12:39 PM
T Bell T Bell is offline
putting a manual in "Park" will get some getting used to.
Old 06-16-2006, 05:53 PM
quadfather quadfather is offline
IT SOUNDS PROMISSING . I WONDER IF THE PLANETERIES WILL HAVE CLUTCH PACKS LIKE A LENCO OR TRADITIONAL AUTO'S. IT WOULD BE A GOOD STEP IN MAKING A 6-SPEDD THAT WOULD HOLD UP TO BIG H.P. THE CLUTCH PACKS TEND TO CUSION THE GEARSETS A BIT. AND NO CLUTCH TO SHIFT YEE HA!
Old 06-16-2006, 08:33 PM
tyoneal's Avatar
tyoneal tyoneal is offline
It looks like fun!
Bring on the Shrifter!!
tyoneal
Old 06-16-2006, 10:55 PM
Um, that looks like an auto on every bit of the design. Has an oil pan, uses planetary gears, has no shifter, or linkage, and has a P in the gear pattern. I'm guessing an auto controlled by an electronic shifter that has a 'pattern' built into the unit so it seems like you are rowing gears. This might be manumatic at its finest, but a full manual trans this isn't.
That last line sounds like something Yoda would say. Screw it- the sentence stays.
EDIT:
I'm an idiot. One should read (not just look at the pretty picture) about the features in the .pdf before posting about it.
/Moron mode off.
Tyler
