Old 01-26-2014, 07:18 AM
Windsor GTO's Avatar
Windsor GTO Windsor GTO is offline
Default 2004 GTO project
Attached are a couple pictures to get it started.
It is a 2004 GTO 25.2 chassis, 9" rear the ladder bar is 3 way adjustable with the option to remove top bar and make it 4 link(which it is), rear seat delete, 31x18x15 in back with 26x6x17 in front.
Old 01-26-2014, 07:44 AM
Cool! Welcome to the site.
Old 01-26-2014, 10:09 AM
DETON8R's Avatar
DETON8R DETON8R is offline
looks like a lot of work ahead.
Keep the pic coming.
DETONATOR - 69 Camaro RS
LS1 - T56 - Chris Alston Frame - 2" drop
G-Link Rear - 4.20 gears in 9" - Mini Tubs
Old 01-26-2014, 01:10 PM
Che70velle's Avatar
I hear rumors of Ford power. Looks like someone cut a big hole in the hood. Tell us more!
Thanks Dad!!
Old 01-26-2014, 05:34 PM
Default Rumors
I was building a Mustang like almost everyone else...lol. it was almost complete and then a friend of my Chassis guy had a deal I could not pass up.
A 2004 5.7 GTO 25xxx miles zero accidents, on stands waiting for the narrowed 9" to be put in and a cage but he lost interest. so a incredible deal was struck and it was mine. I sold my mustang roller and ended up only $700 out of pocket for the GTO. The hole was for the 6.0 with a Hogan carb intake. I was not a complete motor. also had new twin 76mm turbos 2 waste gates and blow off valve.
I already had a built 5.7 Windsor so I figured why not.....
scrapped the 6 point cage in favor of a 25.2 chassis 20 inches of wheel clearance per side. Cage and sheet metal should be finished by Feb 22nd.
Old 01-28-2014, 07:27 AM
Default somemore details
the engine is a 351 SVO block half filled completely de-burred running a dry sump oil system.
Stroke 4.100 4340 forged
bore 4.030 JE 12.4-1
rods 6.250 4340 forged
Custom bullet cam, Crane pro series lifter, 3/8 thick wall chromoly push rods, manely double springs, T&D rockers.
Yates C3 heads, Titanium intake valves, extreme duty SS exh valves
Crank and rods have oil sheading coating
Pistons, wrist pins, valve springs, intake and headers were coated by Polydyn coatings.
Old 01-29-2014, 07:40 AM
Rexter's Avatar
Rexter Rexter is offline
so far so go that should move out nicely
1950 Pontiac on a 84/85 Regal chassis.
Old 01-29-2014, 07:54 AM
strtcar strtcar is offline
Looks good
Old 01-29-2014, 08:31 AM
no go nova's Avatar
no go nova no go nova is offline
Are you taking the compression down are you running another fuel?
Old 01-29-2014, 11:33 AM
Default Compression
Leaving compression at 12.48 looking to run E85 as the supermarkets sell it here in the gas stations.
Going to sell off all the LS parts and turbos soon.
