Old 02-05-2014, 02:02 PM
goob8869 goob8869 is offline
Default reasons for dbw throttle not working?
I have finally got my ls6 conversion cranked and idling perfect but now I have no throttle what so ever. It is like it is not even in the car. Checked all the wiring again but it is all connected. If the tps goes out will it make the gas pedal do nothing or just make the car run rough? Need some suggestions
Old 02-05-2014, 04:39 PM
Vince@Meanstreets's Avatar
it will put it in limp mode. are you able to retrieve codes?
have you had the PCM programmed?
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-05-2014, 04:46 PM
Yes pcm is programmed
Old 02-05-2014, 05:48 PM
canrc canrc is offline
I was having a similar problem with my DBW -- after checking and double checking everything it ended up being the pedal itself, replaced it and everything worked.
_________________________
- Raj
'69 Camaro - Current Project
https://lateral-g.net/forums/show...ighlight=MAX-G
Old 02-05-2014, 07:59 PM
Thanks I was wondering if the pedals or tach modules ever went bad. The pedal and module had been sitting in the weather for awhile when we got it.
Old 02-07-2014, 11:34 AM
Bigbore500r Bigbore500r is offline
First step is scanning, did it throw any DBW related codes? Start here
Old 02-07-2014, 02:57 PM
mitch_04 mitch_04 is offline
If you have access to the PIDs, check APP and TPS with key on engine off. Press the pedal down and see if they are changing.
Old 02-07-2014, 06:14 PM
New DBW pedals are $75 at JEGS --- I'd be ordering one.
Old 02-09-2014, 07:36 AM
Mike Norris Mike Norris is offline
Supporting Vendor
As mentioned before, I would be checking for codes before buying and throwing parts at it.
What harness do you have (company done by)? I have seen plenty of GM and other companies harnesses have issues out of the box. The exception is Speartech as they test each harness on an engine.
Are all the parts from the same vehicle (pedal, TAC module, ECM)? Not all of these parts from different vehicles are compatible. Some are, but not all.
So check the codes and compatibility first.
Mike Norris
Mike Norris Motorsports
Raymonds Performance
3828 Clarks Creek Road
Plainfield, IN 46168
407-616-2518
www.mikenorrismotorsports.com
[email protected]
Visit Our Facebook Page
Old 02-09-2014, 12:36 PM
frankv11's Avatar
frankv11 frankv11 is offline
So will a tac module work with any same year and model car. Or does it need to be specific to car which it came from
