Old 02-27-2014, 06:49 PM
samckitt's Avatar
samckitt samckitt is offline
Default Ford T56 VSS connector?
Anyone know where to get the parts for this connector, body, terminals & seals?
Scot
86 Monte SS
LS2/T56 Magnum
Old 02-27-2014, 08:40 PM
Revved's Avatar
Revved Revved is offline
When I've ordered my T56s directly from tremec I've ordered them with the connector. It comes loose in the box so unfortunately I don't have a PN for you. Have you tried a Ford or GM dealer? I'm not sure if either/or use the VSS in the trans but that may be a possibility.
Otherwise I would try any of the number of guys selling modded T56s. Break open your favorite car mag and there will be half a dozen in there.
-Sean
Comp Performance Group
Business Development Manager
1970 Chevelle I built years back as a Lat-G Feature https://lateral-g.net/forums/showthread.php4?t=43116
Old 03-09-2014, 09:50 AM
408sbfmustang 408sbfmustang is offline
Try American auto wire and summit
http://www.summitracing.com/parts/cm...commendedparts
Old 03-25-2014, 11:04 PM
TAC TAC is offline
Check with Pico, they have it...PN 5755
71 bronco...fully custom built...daily driver
69 Torino...to be built
gary
Old 04-08-2014, 07:55 AM
Black93GT's Avatar
Black93GT Black93GT is offline
I believe you're looking for this connector.
CAD Drawing
Page 9/10 shows the connector pins and seals
https://delphi.com/connectors/assets...hure/gt150.pdf
I've been ordering all my Delphi plugs from Mouser. If you're able to crimp the pins you can for far cheaper than the places that sell the plug with pigtails.
Old 04-08-2014, 08:37 AM
samckitt's Avatar
CAD Drawing
Nope not it, that is the one for the stock GM T56. The Magnum uses a Ford connector.
It looks like:
Sure I can buy this connector pig tail, I have already bought one, i prefer to find the connector body & terminals & crimp them on.
Scot
86 Monte SS
LS2/T56 Magnum
Old 04-08-2014, 12:44 PM
Vince@Meanstreets's Avatar
It looks like:
Check with the Ford guys at the dealer, you can buy or get the pin terminals from them. I had a bunch of random pins just layin around. Since you have a pig tail all you have to do is take it apart. Easy.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 04-09-2014, 07:43 AM
Black93GT's Avatar
oh I see the problem... Ford parts in a GM. Just swap the sensor for a propper GM version.
