Old 05-15-2006, 07:37 PM
Default Need Help with a 4-link
Hopefully you guys can help. I'm working on a 1/12th scale 69 Camaro. The aftermarket is slim to nil so i have to scratchbuild just about everything myself. I plan on do a 4-link suspension out back. I would like to replicate the DSE set up. If anyone has any pictures of this kit installed, that would be great. I am using scale 11" wheels so It will have to be tubbed. What diameter tubing is usued for the links?
Also, does anyone know the diameter of the driveshaft off the top of your head?
Any help would be absolutely great.
Russell
1/12th scale 1969 Sunset Orange Metallic Camaro Pro Touring Style>>
Progress Thread
Artwork Page
Old 05-16-2006, 08:23 AM
astroracer astroracer is offline
Russell,
If you use a scale 1 1/2" dia. (0.125 o.d.) tube you will be good for the links.
Most stock driveshafts are 2 1/2 or 3" in diameter. 1/4" or 5/16ths O.D. aluminum tube will polish up nice and look good.
Mark
"Bad Ast" Astro Van Pro-Touring Project.... Heat, beat, file to fit, paint to match...
Old 05-16-2006, 09:13 AM
thanks for the help....anyone got some pictures. I'd like the placement and links to look like they should!
Progress Thread
Artwork Page
Old 05-16-2006, 09:58 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Russell, is this what you're looking for?
https://lateral-g.net/forums/showthread.php4?t=4354
My LS7 69 Camaro
Old 05-16-2006, 10:40 AM
Scott,
I forgot about that thread. Those pictures are tons of help. I am also contemplating on reworking the rear end. I believe the rear-end in the kit is a 12bolt which is nice. I might make some brass axle tubes so I can add more detail around the end, and tu sturdy it up some to help it all support the weight. Anyone got some under car shots?
Progress Thread
Artwork Page
