Old 03-17-2014, 08:57 AM
OBeer-WAN-Kenobi's Avatar
Default Camaro Subframe Alignment Pin Dimensions
Does anyone have the dimensions for the alignment pins used to help align the subframe when mounting it to the car? I figured I'd just make a set and it would be easier to have the dimensions ahead of time instead of measuring it under the car.
I think the diameter should be about .609 correct? It's the lengths I'll need. Overall and to the step.
Thanks!
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 03-17-2014, 04:44 PM
Vince@Meanstreets's Avatar
I have a pair of alignments shafts I made years ago from 5/8" steel rod. thats .625in diameter and 10" long. Actual length doesn't matter the hole goes up into the body. It would depend on the bushing you use. I made them long to get the leverage.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 03-17-2014, 05:57 PM
mikeextrafast's Avatar
mikeextrafast mikeextrafast is offline
we are getting ready to remove the front sub frame as well.... whats the proper way to reinstall it so its in the wright position?
Old 03-17-2014, 06:54 PM
On a lift hoist we usually use a plumb bob to get it close. Lower the body about a 1/2" of clearance then put the bushings and bolts in loose, then shift the body around with the rods to line the frame to body.
Dealer for
NEVER FORGET -11
Old 03-17-2014, 07:59 PM
rsgt's Avatar
rsgt rsgt is offline
There is a hole at the front of the rear frame rails just in front of the front leaf spring mounting bracket, use this hole to cross measure to the lower front ball joint grease fittings. When you have both measurements the same the subframe will be square to the body.
Randy
spoilersbyrandy
Old 03-17-2014, 10:57 PM
clill's Avatar
clill clill is offline
I always used old lug wrenches.
Old 03-25-2014, 01:26 PM
I think this good way to get it straight.
63 Z06
Old 03-18-2014, 06:57 AM
If 5/8" fit's I can certainly use that. The book calls out .610 +0/-.002 if I recall correctly. Being .015 bigger in diameter, a 5/8" pin should theoretically get you closer off the bat (if it fits) but it makes me wonder why GM was so specific on the dimension if a 5/8" pin will fit.
'69 RS Camaro
Old 03-21-2014, 05:23 PM
David Pozzi's Avatar
That might be an assembly line spec. The sub and unibody had to meet up and if the pin was too tight a fit, there could be trouble, slowing the line.
http://www.PozziRacing.com
Old 03-21-2014, 06:31 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Could have been and "attribute" or hard check fixture. 5/8" nominal hole size with built in tolerance, or MMC (max material condition) allowance. So it it would equate to a 0.015" true position allowance if 5/8" is really the nominal holes size. I'd be surprised if it was that close back in the day.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
