Old 04-21-2014, 07:45 AM
OBeer-WAN-Kenobi's Avatar
Default OBDII Port
What are you guys doing for a OBDII port in your LSX swaps? I have a factory GTO ECM and harness but it didn't come with the port. I checked into the one at lt1swap.com but it seems the info is a bit outdated on the part numbers because I can't find the same stuff on digikey (at least the last time I checked).
Does anyone make a port I can just buy and wire in?
Thanks!
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 04-21-2014, 08:00 AM
Che70velle's Avatar
I'm using a PSI harness that has the port already wired in. I'm sure you can do this, no problemo.
Thanks Dad!!
Old 04-21-2014, 08:27 AM
That's cheating.....
You did give me a good idea though. I think I'll call PSI and see if they will just send me a port.
'69 RS Camaro
Old 04-21-2014, 11:42 AM
I just ordered one from PSI
Thanks!
'69 RS Camaro
Old 04-21-2014, 09:08 PM
Che70velle's Avatar
Spoke to Jon today myself. He's always around, and if not he returns phone calls. He can tell you the pinout for it, or you can always find it over on LS1tech.
Thanks Dad!!
Old 04-22-2014, 10:17 AM
samckitt's Avatar
samckitt samckitt is offline
You want just the connector to wire in?
http://www.eficonnection.com/eficonn...spx?ItemId=817
http://www.eficonnection.com/eficonn...spx?ItemId=818
Scot
86 Monte SS
LS2/T56 Magnum
Old 04-22-2014, 02:34 PM
Originally Posted by samckitt View Post
Yeah, that's what I wanted. I just ended up ordering one from PSI.
For some reason, I couldn't seem to find them myself. My google-fu must be weak this week.
'69 RS Camaro
Old 04-23-2014, 04:21 AM
charchri4's Avatar
charchri4 charchri4 is offline
Just go to a bone yard. With very few exceptions they are all the same from 97 to now. The plug I am using is out of a cavalier as I recall and was a buck.
Jim Stainer
No it's not a muscle car but it has a lot of muscle!
