Old 04-24-2014, 05:07 PM
redfire69's Avatar
redfire69 redfire69 is offline
Exclamation Help - GM power steering lines
So I've installed GM performance parts serpentine kit 12497697 which includes a power steering pump with the 16MM-1.5 o-ring connector. I've got the 11/16"-18 at the steering box. I've tried twice with the Russell 6AN lines using the adapters at each end.
Each time, the Russell PS lines have leaked at the compression fittings that are supposed to be leak-proof, LOL. I'm trying Earl's PS lines tomorrow if the parts arrive. Does anyone know of a stock line I can use for this application (help, GM Gurus!)? Otherwise does anyone know of 6AN PS lines that actually work?
Thanks, Ron
Ron
69 Camaro Redfire
Old 04-24-2014, 05:26 PM
camcojb camcojb is offline
Thanks, Ron
I assume you're using the teflon lines for that much pressure. It's critical to get the teflon end cut perfectly straight without any burrs or knicks in the edge. Unlike normal rubber braided lines that seal on the inside of the rubber hose itself, the sealing part of the teflon lines is the end edge of the teflon where it meets the farrel nut. If it's not a clean straight cut they will leak.
I always cut the hose and then peel the braided line back a bit so I can get a sharp straight razor blade on the end of the teflon only, and carefully cut it perfectly straight and perpendicular to clean up any roughness on the edge from cutting the hose.
Old 04-24-2014, 06:05 PM
The US is weird lol try any shop in Canada they can make one for you or possibly sell you a metric fitting
Ryan Austin
Old 04-24-2014, 06:18 PM
redfire69's Avatar
Thanks, yeah I'm using the high pressure lines, I didn't straighten them up with a razor. Do you know if the farrel nuts are reusable?
Ron
69 Camaro Redfire
Old 04-24-2014, 09:11 PM
Once they've been tightened down they're compressed doubt you can even get them off the teflon liner. You'll need to replace them regardless, one time use IMO.
Old 04-24-2014, 09:46 PM
dale68z dale68z is offline
Swap out the o ring fitting in the power steering pump for a flare fitting from an older vehicle with flare style hose. then you can use a stock pressure hose.
