Old 04-24-2014, 10:35 PM
69greyghost 69greyghost is offline
Default Guys, what are some must haves for restomod pro touring cars?
Guys, I have been working on my car for a little over a year now and was running through some ideas for some essential upgrades for a pro-touring / restomod car. The car is a 69 camaro, it currently has an ls1 with a t-56 and dakota digital gauges, qa1 triple adjustable coil overs in the front, hotchkis big sway bar, hid lights, and electric rs doors over the air operated systems. i guess what I want know is with this being a cruiser that will never get auto crossed, raced or anything like that, what are good upgrades to build on what I have? I want to mini tub but considering I have the stock width gas tank already that seems futile, I was also thinking vintage air is a good upgrade, and finally I thought that maybe dressing my ls up would be a good idea. Let me know what you guys think, any and all positive suggestions will be taken into account and thanks in advance guys.
Old 04-25-2014, 07:00 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
I'm a fan of functional modifications over bling - AC; interval wipers; windshield washers; really good seats; sound system (maybe with blue tooth); exhaust system that won't drive you crazy when you drive the car 10 hours in a day; camber correction for the front end; solid body bushings; delrin/del-alum (or equivalent in aftermarket arms) UCA/LCA bushings; upgraded steering box; disk brakes front and rear; subframe connectors; good shocks and springs on the back end (I'm partial to composite leaf springs); a gas tank and pump that will reliably supply fuel until it's virtually empty.
Me, I wouldn't "dress up" the LS1 - it is what it is. I'd put the money into something that made the car work better.
Old 04-25-2014, 01:15 PM
ArisESQ ArisESQ is offline
You don't need a narrowed gas tank to minitub a Camaro.
Old 04-25-2014, 03:36 PM
Those are some good starting suggestions I think, I have the gen 5 brembos I want to use, and I also put the gen 5 seats in my car for comfort. I think vintage air, mini tubbing and a really nice sound system may be my next direction. Thanks!
How do you do that and what size tire could I run without a narrowed tank? Is there a kit out there that works with the factory tank?
Old 04-25-2014, 03:48 PM
The tank itself isn't at all in the way of the minitubs. A narrower tank just allows more room for the exhaust pipes to run through as far as I understand.
I have the DSE minitub kit + qudralink on my 67' with a stock width gas tank and can fit a 335.
Old 04-25-2014, 04:24 PM
califconstruct's Avatar
califconstruct califconstruct is offline
If you stick with the leaf springs, and offset shackles, you'll need to narrow the tank to make it fit.
If you have a 4 link or Torque arm, no need for a narrowed tank.
I had a buddy of mine cut and re-weld 1" off of each side of the stock tank to make mine fit. 200.00.
Old 04-25-2014, 04:36 PM
Ron in SoCal's Avatar
Must haves:
- Patience
- An understanding GF or wife (or both)
Ron in SoCal
69 Camaro in progress
Old 04-26-2014, 09:52 AM
Thanks for clearing that up - I did the quadralink at the same time so it never occurred to me that I'd need a narrower tank had I kept the leaf springs.
Old 04-26-2014, 10:03 AM
Based on your description I'd add a modern console, tinted windows, and modern 3 point belts to the discussion.
Old 04-26-2014, 12:17 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Does your LS1 have fuel injection? I am not sure why you want to stay with the stock tank? Typically, most people upgrade to Rick's tank with the fuel pump inside. If you plan to have 3 inch exhaust out the back, then you need a narrow tank. My 67 Camaro has Narrow, Notched, stainless steel tank (with dual fuel pumps) from Rick's http://www.rickstanks.com/ I saw one post on a guy modifying the stock tank. Well, I had one modified in the past. In 2000, I had to buy a new stock tank, and we had it cut and welded for sump. Then I had to have the stock tank tested for leaks. I was lucky in finding a local radiator/hot rod shop for leaks. I heard that it is hard to find a place to test the tank now. I had probably about $600 in that tank, but I think the best option now is just have Rick's build you a tank. There is several vendors on the forum that have the tank already ready to ship to you.
My car started off getting a frame off restoration on Rotisserie, but one of the first upgrades was mini-tubs. Mini-Tub is the most expensive option, because you have to get a rear end narrowed. Custom wheels for the 335's. I bought new NOS outers for mine, because I was replacing the factory quarters. Some Camaro's require new frame rails, but mine was solid. Rear suspension, do you want leaf springs or Quadra-link, etc. At the time, there was only the leaf springs and offset shackle kit. Although, I went to a Good Guy's show, and bought the quadra-link #1 (first one that was sold). Kyle agreed to take my never used leaf spring kit back. (Actually, most people upgrade to the quadra-link if they have leaf spring kit) Later we found out the Quadra-link test car was based on a 69 Camaro. The 69 Camaro is a few inches longer, so just say that mine was moved more than once. The advantage of doing a frame off restoration, you will find sheet metal that needs to be replaced. A friend of mine was building a cruiser car 69 Nova, and I told him that most likely the subframe mounting points were rusted out. He kept telling me they were fine, but he never checked. Anyway, they pulled the subframe out of the car and found they were rusted out.
The original plan for mine was to use the stock subframe, but then DSE brought out the front subframe. So, I upgraded to that as well. If you are following Camaro XV, then you notice the new motor mounts that Mark has put on his car. Mine has that as well, because I am in the same shop. Reduces vibration and noise. I always liked the Fiske 5S, so I have no plans of changing that option.
The brakes I used was Baer Extreme+ 6S brakes, they fit the C6 Spindle. The DSE subframe has Corvette C6 spindle, so your brake system has to match your spindle. I am not sure if the Brembo Gen 5 brakes from the Camaro will work on your subframe. The old method for the subframe was to use an adapter, but I sold my Alcon brakes long ago.
My rear end is a Currie 9", but I had that in the past. My old engine was 383 SB Chevy full roller with around 612 hp. (Turbo Blue) The engine would rattle the car, but it was built primary for drag racing at the time. I hated that engine because of the vibration. I planned to upgrade to LS engine, but I made the decision to do a supercharged engine. This upgrade causes you to upgrade several components, but depends on the horsepower/torque. Anyway, the street manners of the engine is like a stock engine, with lot of torque as you press down the pedal.
Vintage air, dynmat, etc. Really it depends on what you want for your car, but the first thing you need be sure that it safe to drive. So expect lot of sheet metal to be replaced. I owned my car since 1983, so I know most of the history. When you take the car apart, then you find out more things about the car.
Jeff
PS. Hid Lights are illegal in most states, but varies on the state. DSE has these bright lights, but not an actual hid. The other option is LED lights, but most of the LED lights won't work with RS option. Not sure on 69 Camaro, but they are to thick for 67 Camaro RS.
