Old 05-07-2014, 09:39 AM
Swain's Avatar
Swain Swain is offline
Default Best Gear Ratio
Looking for the best all around Ration for Street and Some Track days.
68 camaro LS3 480 Cam, T56 6 speed from early 90's camaro switched over to LS style.
335/30r18 Rear tire.
Currie 9" Housing 31 Spline
3.70?
3.89?
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 05-07-2014, 09:48 AM
Sieg's Avatar
Sieg Sieg is offline
Jay - Is the T56 a close or wide ratio?
I just installed 3:73's in my Camaro with a close ratio T56 and 26.6" tire and it's about perfect. I was really leaning toward 3:55's and I'm glad I didn't go that route.
Play with your gear/rpm/mph here: www.tremec.com/calculadora.php
Old 05-08-2014, 04:21 PM
CURVES's Avatar
CURVES CURVES is offline
I just bought the Magnum 2.66, but I had the overdrives changed to .74 and .50.
My thinking was I should have a similar motor rpm as new corvette at 70mph, about 1500. The 2.66 should give me a little more first gear (than the 2.97).
So with a 335/30/18 I'll be at 1650 or so rpm's at 70 mph with a 3.70 rearend ratio.
I hope I got it right!
SCOTT
71 Camaro project. "Mulletmobile"
66 el camino "Pye Wagon"
69 Camaro. sold
Old 05-08-2014, 08:17 PM
I run a (or should say I ran) a 3:73 in a Ford 9" in my Nomad -- with a 700r4 -- and it was PERFECT but that had rather small diameter tires at 25.6"
The Mustang runs a 3:89 rear but only a 4 speed.... so that's no comparison.
Can't beat a 3:70 for all around good gear ratio IMHO.... or you could run a 4:30 like my little '32.... LOL Nothing like a good gear in a short wheelbase lightweight car! Yippppeeeeeeeeee
Old 05-09-2014, 01:46 PM
Swain's Avatar
Its a short ration 2.66 First Gear. Thanks guys for the info. Time to spend some money... Wife is going to be so happy
Jason Swain
Old 05-09-2014, 04:40 PM
CURVES's Avatar
The 2.66 first gear is the CLOSE ratio version.
Close ratio means you will have less rpm drop when shifting from 1st to 2nd and 2nd to 3rd and so on.
SCOTT
69 Camaro. sold
Old 05-09-2014, 04:46 PM
Sieg's Avatar
Best modification I've done to my car without a doubt. I've had it about two years now and I still thoroughly enjoy driving the car because of that transmission. Hope your feelings are similar.
Old 03-13-2015, 10:32 AM
Nativefx Nativefx is offline
Swain any updates on what you ended up with? I'm about ready to make a decision as well and am looking for feedback.
