Go Back   Lateral-g Forums > Events > Lateral-G's "Members on the Scene"
Old 05-22-2014, 10:17 PM
dale68z dale68z is offline
Default Auto Club ROVAL video
I thought you guys would enjoy this video. This was taken 5 3 14. We were running with Speed Ventures.
There are some famous characters in the video. Starting out you see the butternut yellow 67 Camaro of Tom Foglesong. At about 4 minutes you will see (for a very short period) Jake with his ls7 69 Camaro...he's kinda fast
We ran back to back sessions in this video. It was a 95 deg day.
My car is a 71 Camaro, it is a nothing fancy street car with factory air, decent shocks, nt05's, g braces, and subframe connectors. Engine is a 383, t56 mag trans. 12" 1le front brakes,11' lt1 rear brakes.
We drove the car to the track 6 hours, ran the ROVAL all day then, drove back home 6 hours.
I am talking to my 15 yr old son, who is my passenger. Just in case you thought I was a wacko for talking to myself.
Old 05-30-2014, 07:51 PM
LM7_67 LM7_67 is offline
Wheee!! Flying around the big oval!
1967 Camaro - LM7, T56, TVS, 12.7:1
1996 Impala SS - DD
Old 05-30-2014, 09:01 PM
CURVES's Avatar
CURVES CURVES is offline
That's some fun right there!
SCOTT
71 Camaro project. "Mulletmobile"
66 el camino "Pye Wagon"
69 Camaro. sold
Old 06-01-2014, 10:07 PM
I was cool with the speed on entry of turn 1 on the oval, at first. We initially were about 130ish mph on the first couple of sessions. As we got more confidant and started to enter closer to the wall were at 140 mph. The last session we gained 12# of tire pressure. My brain started to work. I became a bit worried about a tire issue sending us into the wall. There would be absolutely nothing I could do to avoid the outside wall if a rt front tire went down.
So, we didn't slow down, just didn't try to go faster.
It was great fun, and the experience was made even better because my buddy Tom LM7_67 is on track with us.
Old 06-02-2014, 05:17 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Cool!
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 06-02-2014, 05:52 PM
hit 140, lift, apex at 112, get up to 130 again before braking for what felt like a really tight left/right combo....
1996 Impala SS - DD
Old 06-02-2014, 06:07 PM
Track Junky's Avatar
Thanks for posting. I've never been on that track. Looks like fun. Certainly looks like you can reach well above 140 if you wanted to.
12 lb hike in tire pressures is huge. Goes without say but you might want to drop a little more air out of the tires next time out.
Just out of curiosity what were your tire pressures cold?
Gaetano Cosentino
Old 06-02-2014, 07:39 PM
We start out with 33 front and 28 rear. The car weighs 3619 then throw in 400 # of driver and passenger. Typical tire temps are about 10 deg diff outside center and inner. My inner is higher temp. But I had added an 3/8 addl - camber. My old camber setting of a heavy 2 deg had my tire temps pretty even across the face.
Old 06-02-2014, 08:24 PM
That is a heavy car. If it were me I'd be thinking about a brake system upgrade.
So you were at 45 lbs hot up front and 40 lbs rear? I know there have been a few guys that have run the NT-05's on here. Maybe they will chime in with some recommended tire temps.
Gaetano Cosentino
Old 06-02-2014, 08:34 PM
Before I came back to comment - or saw the other comments - I was thinking to myself --- WOW -- the tires really started losing grip once they got some heat into them... That would be the OPPOSITE of what I want out of my tires! LOL
Fun to watch video!
