Old 05-24-2006, 03:25 PM
350ZNV 350ZNV is offline
Default Anybody tried the MSD 160amp APS Alternator?
I am not sure if this should be in this section or the engine section, so mods feel free to move if necessary .
Well, I came to the conclusion today that I need a stronger alternator to power all of the things I have going on in my Chevelle. When searching around I came across the MSD Advanced Power System 160amp alternator. Now, the highest I have seen before is 140amp so I am very intrigued by this MSD 160amp application. I am about to order the thing and figured I should check the forums to see if anybody has any positive or negative feedback on this part.
Here's a link to the alternator on MSD's website...
http://www.msdignition.com/1aps.htm
1970 Chevrolet Chevelle
Pro-Touring Project
Funded by me, Built by ATS.
Old 05-24-2006, 05:10 PM
I have a friend that tried one, tested only went 150 amps which was more then enough for him, but I wanted to see what it could do. There has been some negative stuff on them around, but you know how the internet is. I do not like the look, nor the fact you have to buy mounting tabs and pulley seperate. So I have been using Tuff Stuff 140amps. They are testing at 150 amps, are pretty polished, and I get a good deal on them. They are over $100 cheaper then the dressed MSD. Under $300 for the Tuff Stuff.
JMO
Old 05-24-2006, 05:13 PM
Thats interesting...
150amps should be plenty better than my current 100amp either way. Thanks for the opinion! Anyone else?
Pro-Touring Project
Old 05-25-2006, 05:47 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Frank, what's the Tuff Stuff current rating at idle speed?
My LS7 69 Camaro
Old 05-25-2006, 08:17 AM
I could not get a idle rating Scott, I can tell you it turned on very early.
Old 05-25-2006, 05:07 PM
Speedster's Avatar
Speedster Speedster is offline
PowerMaster makes a 200 Amp if you need any more power.
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
Old 05-26-2006, 03:46 PM
JamesJ JamesJ is offline
I second Powermaster they make lots of high output ones. Lots of people use them in the high performance car stereos.
James J.
