Old 06-01-2014, 07:19 PM
jblaine86 jblaine86 is offline
Default Header help
I have a 69 camaro that has a sbc 383 stroker (gen I block) that I have lowered 3 inches from stock height. I was wondering what headers to use? The car will have a pypes CROSSFLOW W/ X-PIPE SYSTEM SGF70. The stroker also was on a dyno with hooker super comps and made 457 hp and 478 lbs of torque.
Thanks,
Jon
Old 06-01-2014, 08:45 PM
Vince@Meanstreets's Avatar
Thanks,
Jon
these have worked for me in the past. you'll need a mini starter.
http://www.summitracing.com/parts/dt...1310/overview/
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 06-01-2014, 09:05 PM
Sieg's Avatar
Sieg Sieg is offline
Doug's D368's also 'snug up' nicely.
Old 06-02-2014, 05:29 AM
toddoky toddoky is offline
What cylinder heads, transmission and transmission crossmember are you using on your set-up?
Old 06-02-2014, 07:27 AM
Sieg's Avatar
Older AFR 190's, T56 Magnum, Hurst Drivelines kit crossmember, standard height subframe bushings.
Old 06-02-2014, 08:27 PM
I am running a t-56 tremec transmission with there supplied cross member. The engine has pro comp heads that a machine shop worked over to get them up to par.. Thank you all so far for the responses.
