Old 06-04-2014, 04:43 PM
jarhead's Avatar
jarhead jarhead is offline
Default Currie drain plug Ford 9"
So does this thing get welded to the hole you make on the inside of the housing, or outside?
Seems like you wouldn't be able to get all the lube out if you welded it to the inside.
Description: Our large drain plug kit features a 1/2" pipe thread allen drive steel plug and an 1 3/4" o.d. weld in steel bung that fits into a 1 1/8" hole.
http://www.currieenterprises.com/ces...E.aspx?id=1578
Anyone have a link for a nice fill plug?
Thanks, Joe
joe
Semper Fi
My 68 Torino
Old 06-05-2014, 03:21 AM
LS1-IROC's Avatar
LS1-IROC LS1-IROC is offline
Honestly, I just used a half coupling and a pipe plug in the bottom of my 9" axle. Drill a hole, weld the half coupling onto the outside. Cost me like $3 for the 2 pieces from the hardware store. This allows ALL the fluid to drain out.
Old 06-05-2014, 07:38 AM
David Pozzi's Avatar
It welds on from the outside. There is a step on the other side to register it to the hole. Usually they weld a little box around the plug to protect it.
You can also weld on a 1/2" fine thread nut & plug it with a short bolt & copper washer.
http://www.PozziRacing.com
Old 06-05-2014, 07:47 AM
jarhead's Avatar
Thanks David, I do like the design of this one.
Joe
joe
Semper Fi
My 68 Torino
