Old 06-16-2014, 07:28 AM
Swain's Avatar
Swain Swain is offline
Default AAW classic update
Can I run a 1969 classic update in my 68 camaro? My column I an ididit and my gauges will all be auto meter and not in stock locations anyway
What do you guys think? I can get a killer deal on one that's the reason I am asking
Jason
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 06-16-2014, 12:47 PM
Musclerodz's Avatar
You can make it work, but the side markers, park signals, and rear taillights, wiper motor switch connections will be different, plus the harness is designed for key column switch, not key in dash switch. The rest is pretty much the same. Unless its free, the extra work will out way the cost of buying the correct one.
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-16-2014, 01:04 PM
Swain's Avatar
I dont have side marker lights I shaved those. I did put in 69 Parking lights in my lower valance and I am running a DSE Wiper motor and Harness. I guess just the key would be the problem
Tail lights are red and I have custom LED Tail lights going in.
Sound better haha
Jason Swain
Old 06-16-2014, 03:15 PM
Musclerodz's Avatar
Key is not a big issue, just have to remove the plug and relocate the wires to a dash style key switch. I assume you did not shave the hole in the firewall?
Mike Redpath
facebook page
Old 06-16-2014, 03:38 PM
Swain's Avatar
Hole is still there. Thanks for the help.
Jason Swain
Old 06-16-2014, 09:22 PM
130fe 130fe is offline
Thumbs up
The DSE wiper integrates pretty easy into the AAW harness. I can post some pics up in a couple of days (out of town on business). I could scan the ignition switch directions to you if needed.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 06-16-2014, 09:51 PM
Swain's Avatar
Thank you you can email at [email protected] when you get back? Thanks
Jason Swain
Old 07-10-2014, 10:13 AM
Swain's Avatar
AAW to PSI Coversion Install. LS3 T56
Any Tricks I need to know about?
Harness is in the car now I am wiring it up, anything tips would be greatly appreciated.
Jason Swain
Old 07-10-2014, 11:33 AM
CamaroMike's Avatar
CamaroMike CamaroMike is offline
All you are really integrating from the psi harness to the chassis harness is the key on wire (red) if I remember correctly. The PSI harness has the plug for t56, the rest of the wires should just be for your gauges and a ground wire. My PSI harness was very simple, just had to de-loom it to extend the MAF wire, they send a extra long harness so you can mount it just about anywhere except the trunk.
Alabama
1969 Camaro
1978 Camaro
Old 07-10-2014, 11:53 AM
Ron in SoCal's Avatar
Jay here's one issue I ran into. Take a look and let me know if I can answer any questions:
https://lateral-g.net/forums/show...postcount=2180
Ron in SoCal
69 Camaro in progress
