Old 06-30-2014, 05:01 PM
ssinister ssinister is offline
Default 454 lsx w/ twin 72mm. Which FI to use?
Working on a project that is going to be powered by a 427 or 454 lsx motor and twin 72mm nre turbos. Transmission is going to be 4L80E built for the power level. I am interested in what injection setup you all would recommend. We aren't looking for all out power numbers, more interested in driveability/reliability.
Both the engine and trans will need to be controlled. Have looked into bigstuff 3, fast, holley, would a factory computer handle this ?
Thanks for any info
Old 07-06-2014, 06:22 AM
supremeefi supremeefi is offline
I wouldn't recommend the FAST or BS3 because of their minimal transient fueling tables. The more available transient tables the more potential for the best drivability.
Mark
Engine builder and tuner.
Old 07-07-2014, 09:56 AM
andrewb70's Avatar
I would go with the Holley Dominator system because it will also handle the programming of the 4L80E.
Andrew
Old 07-07-2014, 11:16 AM
I'm going similar setup (TT 427 LSX) and I'm planning to run the Holley Dominator. As stated it can control the transmission and is very user friendly. Lots of options and very affordable.
William
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 07-11-2014, 03:27 PM
Gas Huffer's Avatar
Gas Huffer Gas Huffer is offline
we suggest the holley kits to our customers running big hp and when they want to run aftermarket computer setups! Good luck with your build sounds like it will make some killer power
Old 07-12-2014, 09:14 AM
gnx7's Avatar
gnx7 gnx7 is offline
We've run the Holley in lots of turbo LS setups and love it. The software interface is very easy to learn/use vs. a FAST XFI etc.
My Chevelle is getting the Dominator setup.
Old 07-12-2014, 09:42 PM
Looks like Holley Dominator it is. We looked at the HP, but it won't control the transmission. I like to keep the amount of things I have to mount under the dash to a minimum to keep it clean and easy to work on. Thanks for the recommendations. I will keep everyone updated as this build progresses. Most everything is ordered, now we are playing the waiting game.
Old 09-24-2014, 09:20 AM
6t9 camaro's Avatar
6t9 camaro 6t9 camaro is offline
How's it going with the dominator?
