Old 07-11-2014, 07:16 AM
mad68rs mad68rs is offline
Default Stalling issues
I have been having stalling issues with my 68 Camaro. It has been my daily driver for about the last 10 years and has been pretty much in the same configuration. It is a 327 powerglide car. HEI flame thrower, edelbrock 1406 (600) The car seems to be runnning better than ever besides the stalling issue I'm having.
The problem: The car will only stall when it is at or very close to close to idle, warm, and in gear. So if I'm coming to a stop or just sitting in traffic. It gets worse as it gets warmer. As soon as you put it in gear it will stall unless you give it a little throttle, but it will still stall if you only raise the idle speed. When it stalls, it acts just like switch was flipped. If I put the transmisison in neutral, the car will not stall.
Things I've done: Replaced spark plugs, cap, rotor, swapped with another 1406 carb, clean air cleaner, new fuel pump, cleaned fuel filter
Enigne: intital timing 8 degrees, 20-24 degrees with vacuum advance on manifold vacuum
21 in Hg vacuum at idle
I'm not really sure what the problem could be. I've been driving it around in this configuration for close to 10 years. Any help would be much appreciated. You know how you can get to your wits end with problems like these. Thank you.
Old 07-11-2014, 09:37 AM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
I'm more of a stick-shift kinda guy, but could it possibly be the torque converter going? Would make sense if it does it in gear...
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 07-11-2014, 10:39 AM
Sieg's Avatar
Sieg Sieg is offline
"like a switch was flipped"
......is there a safety switch on the auto linkage that could be bad/loose/out of adjustment?
Old 07-11-2014, 01:21 PM
novahollic's Avatar
novahollic novahollic is offline
Possible ignition switch/neutral safety switch?
Old 07-11-2014, 03:43 PM
Vince@Meanstreets's Avatar
pull your dist cap off and look at the pick up coil and module. see if the pick up looks overheated, oiled up and check the connector. could be a module issue too.
Do you still have your old yellow wire that ran to the coil from the R terminal on the starter? I had a car where they added an HEI but forgot to terminate that wire. It was grounding out on the bell housing on hard acceleration.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 07-16-2014, 07:12 AM
Default Fixed
Thanks for all the replies. I replaced the HEI dizzy with a new one and it looks like the problem is solved. Thanks again guys. Love this site.
