Old 08-16-2014, 10:30 AM
BBORG BBORG is offline
Default 69 AMX- Mustang Suspension Compatability
I own a 69 AMX which I have plans to do a suspension upgrade and convert to a road race/ street rod. I have looked at the Chassisworks website and their front suspension offerings for 60's mustangs look very similar to my AMX's. Does anyone have any experience using mustang front suspension parts on an AMX?
Old 08-17-2014, 08:19 AM
no go nova's Avatar
no go nova no go nova is offline
Why not just do a full frame chassis?
Old 08-17-2014, 08:37 AM
There are quite a few mustangs out there like the one from Maier Racing that use enhanced but stock configuration suspension. And they are tearing it up at the racetrack. I'm not a fan of taking to the body with a sawsall and cutting the body.
Old 08-27-2014, 04:52 AM
mustangracer11 mustangracer11 is offline
You should check this place out. They may have something for you
http://www.freakride.com/product/amx...s-system-copy/
I've seen one amx that had 79-04 mustang suspension on it but don't know much about it. You should also check out jimi days amx there is a build thread on pro-touring.com
Old 08-27-2014, 09:09 AM
Chassisworks Chassisworks is offline
Supporting Vendor
Unfortunately, although they have similar configurations, the AMX is not cross platform compatible with the Mustang.
The Control Freaks K-Member uses the Wilwood Pro-Spindle which is a modified Mustang II. The suspension on Jimi's car was all custom built and features a modified aftermarket Camaro front sub.
If you really want it to handle like a modern car it is going to take some special attention. The Street Machine crossmember system would be a viable option. There are two different spindle options; traditional steel or billet with unit bearing.
