Old 08-22-2014, 09:00 PM
DBasher's Avatar
DBasher DBasher is offline
Default Rear end Q's
Need some help on what exactly I need to go from my 2.41 to a 4.10 ratio in the 10 bolt I have. Looking at Randy's R&P site it looks like I need a new carrier for anything bigger than a 3.08....what else is needed?
The axle is out of a 78 Camaro, I still need to check if its 28 or 30 spline and like I said its currently a 2.41 ratio.
Thanks for any input
Dan
Old 08-22-2014, 10:05 PM
Vince@Meanstreets's Avatar
Dan
I believe the 3 and 4 series relates to 12 bolt (8.875) only. 10 bolts have under 2:73 and over 2.73 gears. So just the correct carrier and gear ratio....if its a late 8.5 its 30 spline. If it is 28 then do new axles too and go to 30 spline.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 08-23-2014, 09:29 AM
DBasher's Avatar
Thanks Vince, again.
Is it a pretty straight forward install or better off letting a shop handle it? I've only done an 8-3/4 and a 9" and they were set up and just needed assembly.
Dan
Old 08-23-2014, 10:10 PM
Dan
Its pretty easy to do but I've done a bazlion of them. The hardest part is setting the pinion depth. I have a set of tools and modified bearings to get it done quick.
BUT:
Check around, most shops only charge $2-300 to do a gear swap and set up.
Dealer for
NEVER FORGET -11
Old 08-23-2014, 10:19 PM
Sieg's Avatar
Sieg Sieg is offline
Dan that's one area I'd look for a seasoned veteran to do the set up.
Motive ring & pinion sets maybe be the most consistent as any when it comes to not making noise.
I just had mine done and it's a quiet as the 3:31 OEM set I replaced.
Old 08-24-2014, 09:49 PM
DBasher's Avatar
Thanks for the info guys, I'll call around this week and get some pricing now that I know whats needed. I'm a cheap ass and may end up just going the 8.8 route.
Dan
Old 08-24-2014, 09:52 PM
Dan
:save as signature for the next time you get out of hand. LOL
Dealer for
NEVER FORGET -11
Old 08-24-2014, 10:57 PM
DBasher's Avatar
Me? Get out of hand....Were you at the hotel in Portland?
