Go Back   Lateral-g Forums > Technical Discussions > How To's, Tips, and Tricks
Old 09-08-2014, 03:52 PM
camcojb camcojb is offline
Default DSE Quadra link install
Here's a quick write up that Scott did when he installed a Quadralink on his 69 Camaro.
DSE Quadralink install
Old 02-02-2015, 09:38 AM
Revved's Avatar
Revved Revved is offline
Great Writeup!
I will throw out a great plug for DSE... They include great installation videos with their products as well. I put an Alumaframe and rear deep tub kit in the current 67 Mustang build and found their videos very helpful!
-Sean
Comp Performance Group
Business Development Manager
1970 Chevelle I built years back as a Lat-G Feature https://lateral-g.net/forums/showthread.php4?t=43116
Old 07-14-2016, 09:07 AM
l2azorback l2azorback is offline
Very Nice write up! Thanks
Old 08-13-2016, 09:27 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
I know everyone has their method, but I highly advise against welding on the suspension brackets after the housing ends have already been installed.
At minimal an alignment bar and applicable fixture blocks/pucks should be used while welding the suspension brackets. This will keep movement to a minimum at the housing end.
Ideally, the suspension brackets would be welded on first, then the housing ends for a perfect installation.
Hope this is helpful in addition to the above nice write-up.
Jay
Old 06-10-2017, 12:06 PM
speed_m5 speed_m5 is offline
Thanks for the write up
