Old 09-09-2014, 02:34 PM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
Default Couple LS Engines
Item Location (City/State): West Palm Beach, Fl
Price: $4000
Description:
1st Engine -
Brand New L77 engine. 6.0L with LS3 heads. engine was installed and filled with fluids, and during install of engine oil cooler, engine coolant quick connect plug was cross threaded in. they tried to remove the plug and straighten it, and the threads were pulled out. they tried to seal it unsuccessfully and replaced the engine again. that's when i bought it with intentions of looking for a tap or just welding the coolant plug hole shut. the hole is not needed for any vehicle besides on caprice to my knowledge. This engine is brand new, never fired, just fluids added. still has 8 qts of gm dexos in the pan. and some coolant still in the block. Asking $4000 plus shipping.
2nd Engine -
L77 engine, 6.0L with ls3 heads. ~25k miles, i have personaly heard this engine run, engine has been torn down, has worn camshaft and lifters, no other problems. Asking $2000 plus shipping. SOLD
3rd Engine -
L92 Bare Block, Had hole in side of block, was welded shut and new sleeve installed in cylinder #8. Block sat on bench for a couple weeks then cracked by the 4th main. can be welded again, or used as mock up block. Asking $300 plus shipping
1st Engine -
Plug Hole
2nd Engine -
3rd Engine -
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
