Old 10-27-2014, 07:20 AM
cwylie cwylie is offline
Default First Gen ECU mounting
Where are most people putting them? I am running the Holley HP EFI setup and I think I have enough harness to make it to under the passenger seat. Anyone else mounted an ECU there?
Old 10-27-2014, 12:48 PM
SuperB70's Avatar
SuperB70 SuperB70 is offline
In coupple last builds I've put them inside the dash, just over the glovebox.
, Juhani
Old 10-27-2014, 02:41 PM
hifi875's Avatar
hifi875 hifi875 is offline
made a plate out of aluminum and mounted my holley ecu tucked up under fender behind core support in my 69 camaro
69 camaro
03 z06
90 mustang coupe
1950 international l110
1993 mustang gt
Old 10-28-2014, 04:51 PM
tictakman tictakman is offline
I put my ecu against the firewall on the driver side, inside the fender.
Z
Old 10-29-2014, 06:30 PM
jwcarguy jwcarguy is offline
Banned
mine is installed under the 2013 5th Gen Camaro console
it is a LS2 (gen III 24x, "411" pcm)
Jeff
Old 10-29-2014, 07:22 PM
fishface's Avatar
fishface fishface is offline
Awesome job Jeff. Is it forward of the guage pod? Also, are those 5th gen seats? (I posted below trying to get some info on that).
Old 10-29-2014, 09:12 PM
Banned
The pcm is actually mounted ( using a stock GM pcm mounting bracket) under the front of console / gauge pod
The seats started as new Hunsaker Motorsports that I had recovered / reworked by a buddy that owns a upholstry shop here that I also built a LS2 engine for it trade for both front and rear seat reupohlstry done
Thanks Jeff
Old 10-30-2014, 01:42 PM
Moose Moose is offline
mounted mine above and behind the glove box.
Old 01-01-2015, 03:09 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Are you running AC
Old 01-01-2015, 06:35 PM
69x22's Avatar
69x22 69x22 is offline
Mine is a 02 Camaro ECU mounted behind the glove box door. Has AC too.
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
