Old 11-03-2014, 10:33 AM
ProTouring442's Avatar
Default L99 (LS-3) Compressor
On my father's '59 Impala we using a 2010 Camaro L99 (LS-3/6L80). We are using the factory Camaro A/C compressor, and need to adapt lines to it. Does anyone know where I might procure adapters/fittings to go on the Camaro compressor?
Thanks!
Bill
Old 11-05-2014, 09:39 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Better check with the manufacturer of what ever A/C unit you are going to use to see if that compressor is compatible..........Just say'in....
Old 11-05-2014, 08:43 PM
We made the HVAC from a few different early 1970s GM cars. Nonetheless, their really isn't anything that would make a compressor "non-compatible," save it being unable to move enough refrigerant to keep the evaporator flooded.
Old 11-07-2014, 06:52 AM
71RS/SS396's Avatar
The oem LS compressors are variable displacement.
Old 11-07-2014, 05:25 PM
And???
Old 11-08-2014, 05:43 AM
71RS/SS396's Avatar
Originally Posted by ProTouring442 View Post
And???
Does your a/c system have a way to control it? That's the reason the aftermarket a/c companies recommend not using the stock compressor. I'm no a/c expert just going on what I was told by Vintage Air. My guess would be the ecu uses pwm to control the compressor based on whatever parameters are set-up in the ecu.
Old 11-08-2014, 07:56 AM
Got ya!
Hmmm.... since the displacement is controlled by the pressure in the high side (Article) and the 2010 Camaro compressor has a clutch, it shouldn't really matter.
I am pretty sure (99%) the compressor we used for our '56 build (1996 Corvette LT4) is a variable displacement as well, and it works beautifully.
