Old 11-07-2014, 01:07 AM
dean dean is offline
Default 69 camaro tail light install help!!!
Can anyone tell me the best way to install the tail lights so they don't leak?I've heard so many people have problems-I just got digi-tails and marquez lens and want to do this right!!! All replies are greatly appreciated-Thanks
Old 11-07-2014, 01:20 PM
Vince@Meanstreets's Avatar
http://www.stevescamaroparts.com/
give grumpy a call and tell him you want the "good "seals. Then use weatherstrip adhesive (black) on the lenses side.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 11-17-2014, 01:10 PM
69hugger's Avatar
69hugger 69hugger is offline
Dean,
I have the same setup as you.
As Vince said, the OEM style molded gaskets work better than the foam ones, and I found kind of wiggling them into place makes them seat better.
Another word of caution...on my car, the trunk weatherstrip leaks a little, and when it does, the water runs from the weatherstrip channel right onto the top of the taillight buckets. With the Digitail plastic push plugs, the water can run in & short out the boards. It may cause some of the LED's to glow faintly, or it can blow a board completely. I know this from experience.
My fix was to get some black plastic caps at the local hardware store, & use black silicone to "glue" them over the top of the upper push plugs. It is not noticeable, and has made them waterproof.
Enjoy the Marquez/ Digitail setup. I get lots of complements on mine.
