Old 11-13-2014, 01:49 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Default Wheel offsets on new Z28??....
I know from the rags, they are 19x11 and 19x11.5 but does anyone happen to know the offsets/backspacings? I'm thinking they would look pretty nice on my daily....
Jeff-
Old 11-13-2014, 09:06 PM
Ketzer's Avatar
Thanks!
I could work with the 5x120 but I will have to do a little calc on that backspace and the 11.5 width... may be a little too aggressive.
And I'm assuming the wheels are even available yet from GM...
Jeff-
Old 11-14-2014, 06:44 AM
slenning's Avatar
slenning slenning is offline
Jeff the wheels are available but you have to give your Z28 vin number to buy them from GM at this point. Wouldn't be too hard to get though, there's a couple of sets for sale on Camaro5 forum already.
I just got a set of them and mounted some Michelin's for a street set for my Z. I had that same thought to see if I could bolt them on my 70 Camaro. I will measure the backspace on the front wheels today but the other day I did a quick measure and thought they were in the 6 1/2" range. The center hole in the back of the wheel is too small to fit the hub on my DSE spindles too, and I hadn't even checked the bolt circle
Steve
70 Camaro - in process https://lateral-g.net/forums/showthread.php4?t=50636
69 Camaro LS7/T56 https://lateral-g.net/members/lenning/
69 Camaro SS396/350hp
64 Chevelle - patiently waiting
2014 Z28 Ashen Gray
2010 Camaro 2SS/RS Black w/White stripes (wife's car)
2015 SS (the 4 door one) Wife's other car
Old 11-14-2014, 08:40 AM
Ketzer's Avatar
Ouch... there's no way a 6.5 backspace on an 11" wheel is going to fit the front of my Vagon... unless I'm going for the skateboard look... or taking it to RS for one of their mega flare jobs.
Jeff-
Old 11-14-2014, 06:23 PM
Rick D's Avatar
Rick D Rick D is offline
Originally Posted by coolwelder62 View Post
Jeff the rear's have a 7.4375 back space. If I get time I will measure to front's tomorrow. Also the Camaro has a different bolt circle. I think it's a 5 on 120mm. My 2015 Z/28 has 14mm axle studs.
Wait what??? Um when did you get a Z/28????
Rick
Old 11-14-2014, 08:15 PM
Ketzer's Avatar
All the cool kids have them now....
Old 11-15-2014, 08:25 PM
dhutton dhutton is offline
Z/28 wheel specs:
Fronts: 19x11 ET11
Rears: 19x11.5 ET26
Old 11-16-2014, 07:24 AM
Ketzer's Avatar
Originally Posted by dhutton View Post
Z/28 wheel specs:
Fronts: 19x11 ET11
Rears: 19x11.5 ET26
Thank you sir. Unfortunately they won't work on my ride.
Old 11-16-2014, 08:44 AM
syborg tt's Avatar
If you jump on Camaro5.com Needforspeed is making a knock off set in 20 x 10 and 20 x 11 with zl1 / 1le back spacing. If you jump in know there just shy of $1300 shipped.
Marty-mj
www.garagescene.net www.syborgtwinturbo.com www.2ndcamaro.com
marty-mj
Old 11-16-2014, 01:39 PM
Ketzer's Avatar
Thanks for the info Marty!
Don't really want to make the jump to 20s though. Not a fan of super short sidewalls on our crappy streets. I did pass the info along to the Caddy forum though cuz some of those guys seemed interested.... and that wheel style is killer.
Jeff-
