Old 11-25-2014, 03:57 PM
ALLBOTTLEMONTE ALLBOTTLEMONTE is offline
Default What clutch to run
What clutch should I run that will hold up, little about my set up, 68 Camaro,ls3 416,supercharged,t56 tremec,moser rear end, 373 gear, est horsepower 750 to the wheel,street car, thinking about the rxt clutch , any ideas thanks Jamie
Old 11-25-2014, 05:29 PM
David Pozzi's Avatar
We are using the Centerforce DYAD & love it. I think it wil last longer.
http://www.PozziRacing.com
Old 11-25-2014, 05:41 PM
Default What clutch should I run
Thanks David , how about the slave cylinder
Old 11-25-2014, 07:15 PM
I ran the rxt 3-4k with some road racing, autocrosses, drag mixed in. It was a strong clutch. A little aggressive for the street but manageable. For a dedicated street car, I'd opt for the rst or Dave's recommendation.
Old 12-08-2014, 08:58 AM
gnx7's Avatar
gnx7 gnx7 is offline
I've been loving the McLeod twin discs in anything from 600hp to 1200hp cars.
If you don't plan to drag launch your car on slicks often the RST should drive great with light pedal pressure and non grabby release.
Old 12-29-2015, 11:13 PM
Nativefx Nativefx is offline
Did you ever figure out which slave cylinder you needed to run with a twin disk setup? I'm looking at either the McLeod RST or the Monster LT1-S but I can't figure out whether the slave with Silver Sports hydraulics will work or the Hydramax setup from American Powertrain. I've called 3 times to AP and left messages and I know with the holidays their schedule is "off" but I'm thinking I may look for other options. Hopefully SST can help me figure out if their hydraulic setup with work with either of these tomorrow as I think I'm going to take advantage of their Group Buy package.
Old 01-05-2016, 04:25 PM
andrewb70's Avatar
What transmission do you have?
If you have a LS engine and a T56 the Monster LT1-S uses a stock f-body slave.
Andrew
Old 01-05-2016, 05:42 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Mantic Dual Disc is IMO the best on the market
Old 01-07-2016, 09:40 AM
Andrew
I ordered a T56 Magnum kit from Silver Sport Transmission to run with my LS3. I had originally thought I was going to run the Hydamax hydraulic setup, but after numerous failed attempts to get anyone to answer or even return a phone call I dropped that idea. So in talking over with SST, they also had the McLeod RST clutch and said it would work with their hydraulics so i gave him more of my business. Jeff Kauffman has been great to work with in trying to sort my questions, so hopefully I'll have everything here shortly! Motor arrived this week and now just waiting on other things. thanks
Old 02-25-2016, 05:37 PM
Centerforce's Avatar
Centerforce Centerforce is offline
Our DYAD works great for setups like this!
