Old 12-22-2014, 08:35 PM
Default Cerakote
Figured I would start a new thread instead of building off the other. What's the deal with cerakote? I see that cerakote is a firearms coating but Stielow used it on Hellfire so obviously it has other uses. Can someone give me a run down on why I should consider it for a coating or any other reason it should be considered?
Old 12-22-2014, 10:59 PM
Vince@Meanstreets's Avatar
durable and easy to prep for.
Tough to get regular paint to stick to stainless.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-22-2014, 11:02 PM
forgot powder coating too
Dealer for
NEVER FORGET -11
Old 12-23-2014, 07:25 AM
mitch_04 mitch_04 is offline
In regards to weapons, it's supposed to do very well with repeated friction from semi-auto weapons. Doesn't wear as quickly and does very well against the salt water tests as well. I've used it on a few rifles before. I believe they make high heat paint as well, but don't quote me on that, it's been a few years since I was really into guns.
Old 12-23-2014, 09:01 AM
snappytravis's Avatar
I was looking at this stuff yesterday, looks like it a spray applied ceramic type paint then baked on. Yes mostly gun dealers If you go to there website you can put in your zip code and it will give you a list of dealers. I wouldn't imagine they would have a big oven such as powder coat shops. So probably would not be able to do big parts. Definitely looks cool,
Old 12-24-2014, 07:51 AM
Thanks guys. I may have to look into this when I go to redo my trim one day.
Old 12-24-2014, 06:27 PM
Jay Hilliard's Avatar
Very durable and covers piece without major buildup for areas where tolerances need to be kept.
Jay
