Old 01-03-2015, 10:05 AM
Sieg's Avatar
Sieg Sieg is offline
Default Silverback Carbs?
Does anyone here have or know someone that's using a Silverback carb?
http://www.silverbackcarbs.com/
Numerous elements of the design are impressive though the price is nearing throttle body efi systems sans the efi fuel supply requirements.
The website is 'different'
Old 01-03-2015, 10:11 AM
Rod P's Avatar
Rod P Rod P is offline
those are really cool
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 01-03-2015, 10:57 AM
Vince@Meanstreets's Avatar
...one day you guys will turn to fi and never look back.
looks "interesting"
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 01-03-2015, 12:31 PM
Sieg's Avatar
looks "interesting"
My Wife's minivan has efi.
Old 01-03-2015, 12:43 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
They cost about the same as EFI
Old 01-03-2015, 04:34 PM
Rod P's Avatar
Rod Prouty
Bangshift Stories
Old 01-03-2015, 06:58 PM
Sieg's Avatar
But not when you add a proper fuel delivery system (tank, pumps, lines, vents), electrical, and programing equipment.
Old 01-03-2015, 09:15 PM
JB400's Avatar
JB400 JB400 is offline
What's the cost comparison between this carb, and a Holley based carb with all the different pieces to properly tune it and time to do so?
Old 01-03-2015, 10:04 PM
Sieg's Avatar
Exactly.
I'm running a Holley Ultra HP 650 and you can start to get quite a collection of brass. More important is the time it takes to change it out. The HP also appears to be relatively sensitive to atmospheric change.
That's why I'm really curious to hear about this design and it's tunability.
Yes........I know, efi is self learning.
Old 01-04-2015, 01:29 AM
JB400's Avatar
Exactly.
Another thing to mention, if you went with a different, more powerful engine, you're back at square one again with the Holley based carb, needing a larger carb. Even with fuel injection, you'll have to upgrade your injectors and throttle body.
Being a variable cfm carb like the Predator carbs, you can just reuse the same carb, and just readjust it for the new engine, to a limit of course.
