Old 01-15-2015, 05:06 PM
Radlark's Avatar
Radlark Radlark is offline
Default Need some help.....
I have the chance to to purchase an 04 CTS-V engine and trans (5.7/6sp) with 130k miles on the clock can someone chime in and give me a "ball park" figure of what a setup like this would go for? the motor is still in the car I can hear it run, no mods bone stock comes with EVERYTHING, Thinking of putting it into my wagon, Thanks in advance.
Old 01-15-2015, 05:22 PM
kevin_l's Avatar
kevin_l kevin_l is offline
The ctsv trans hurts the value some being that the tail shaft makes them more difficult to swap. I paid top dollar for my LS t56 with 43k miles, I gave 4800 complete with wiring computer, all acceasories plus a few little extras. The ctsv has an ls6 which helps the value so I'd guess anything under 4 would be fair, but ls t56 combos seem to be a little high in my area.
Old 01-15-2015, 05:29 PM
Radlark's Avatar
Ok so the difficulty lies in the transmission tailshaft? I know that there are a plethora of combos and don't want to bite off more than I can chew with the swap it's going into an A-body I have read and read and read about the many people who have done the swap before me which is some great reading!
Old 01-15-2015, 06:22 PM
kevin_l's Avatar
Yeah the ctsv is a IRS so the no slip joint in the trans yoke. I am sure there are write ups but I don't know the details if you can install a slip joint.
Old 01-15-2015, 06:26 PM
Radlark's Avatar
Ahhhh Kevin thanks you very much!!!
Old 01-16-2015, 08:15 AM
HEEP's Avatar
HEEP HEEP is offline
Could you not get away with putting the slip in the driveshaft? Similar to the offroad community?
Bill
My Build Thread;
https://lateral-g.net/forums/showthread.php4?t=40557
Old 01-16-2015, 10:44 AM
dhutton dhutton is offline
Driveshaft Shop can set you up with a CV joint style driveshaft which is actually a good thing because it can tolerate greater driveline angles, up to 9 degrees. Of course it will cost more. AndrewB70 has a writeup in his build thread.
I also think there is a shifter relocation kit out there.
Don
