Old 02-20-2015, 02:45 PM
RS-Chris's Avatar
RS-Chris RS-Chris is offline
Supporting Vendor
Default George's 1969 Chevelle at Roadster Shop
Thought I would post this '69 Chevelle we are currently working on as a similar guide we did a few months back with a black '69 Camaro. The basic premise being that wheels and stance truly make the car.
Not every build has to be a complete tear down and start from scratch. More often than not, good vehicles with a decent paint and a classic look can get a completely new lease on life without committing to the full cost and timeframe of a ground up restoration. With a solid body, modernized driveline chassis and suspension plus the safety of new wheel/tire and braking packages, this type of build can be enjoyed after a shorter build timeframe with updates and aesthetic changes able to be added as needed.
George's '69 fits this model perfectly. In this case we would be adding a FAST TRACK chassis with 4 link rear, LS motor, Wilwood brakes and Forgeline Wheels.
The beginning: With a ride height most crossovers and SUV's would be proud of, this is our starting point.
Blasting the underside
[B][FONT="Arial"]WWW.ROADSTERSHOP.COM
Old 02-20-2015, 02:59 PM
LS7 Z/28 LS7 Z/28 is offline
I would love to see this thing painted like the Smokey Yunick tribute car that was in Talladega Nights
Old 06-09-2015, 09:00 AM
RS-Chris's Avatar
Supporting Vendor
Time for more pics! (Somehow February turned into June...)
With the underside clean and protected, we turn to the fit up and the couple of small mods required to the factory floor to make the most of a true performance chassis.
IMG_1586 by Roadster Shop, on Flickr
Tub cuts and the pocket areas required to clear the 4-bar perch.
IMG_1930 by Roadster Shop, on Flickr
IMG_1931 by Roadster Shop, on Flickr
Firewall smoothing
IMG_2408 by Roadster Shop, on Flickr
Final fitup with motor and trans and fabrication of stainless exhasut.
IMG_2511 by Roadster Shop, on Flickr
IMG_2514 by Roadster Shop, on Flickr
Trans tunnel fab
IMG_2578 by Roadster Shop, on Flickr
Old 06-09-2015, 09:10 AM
RS-Chris's Avatar
Supporting Vendor
More pics - final underside before it heads for it's protective coating.
IMG_2686 by Roadster Shop, on Flickr
IMG_2688 by Roadster Shop, on Flickr
IMG_2710 by Roadster Shop, on Flickr
IMG_2870 by Roadster Shop, on Flickr
Assembly
IMG_5197 by Roadster Shop, on Flickr
IMG_5199 by Roadster Shop, on Flickr
Don Hardy build motor!
IMG_5437 by Roadster Shop, on Flickr
Old 06-09-2015, 12:40 PM
Justin@EntropyRad Justin@EntropyRad is offline
Default nice!
Cool running gear!
Old 06-09-2015, 01:03 PM
Nice!
Old 06-11-2015, 07:17 AM
RS-Chris's Avatar
Supporting Vendor
Some more assembly shots: Wilwood 6 piston fronts -
Rollers on and heading to the upholstery shop. Plan for the interior is much like the rest of the car, simple, traditional and clean.
Forgeline 'heritage series CR3' wheels arrive and are a perfect look for the car. Modern but still have a vintage look.
Old 06-11-2015, 07:37 AM
Wissing72's Avatar
Wissing72 Wissing72 is offline
Love the build!! Do you have any other pic's of the tail pipes? Do you do other work to the chassis to fit them, or can they be built tight enough to fit? My RS chassis doesn't look like it would clear them. I would like to put some on mine, the turn downs resonate a bunch.
Chris
70 Chevelle. Roadster Shop Chassis, The shop llc/ Jon Lind interior LS3/6speed. Thanks to Precision Classics and Collision Eugene, Or. http://precision-classics.com/
Build thread:https://lateral-g.net/forums/showthread.php4?t=39517
Old 06-11-2015, 08:15 AM
RS-Chris's Avatar
Supporting Vendor
No extra work needed - the chassis is designed to accommodate a 3" exhaust with either the 4-link or the IRS. At the rear, the tips/exit should have adequate room between the outer rear rail and the body.
Hope this helps - any questions on your chassis, give us a call also.
Old 06-11-2015, 08:38 AM
RS-Chris's Avatar
Supporting Vendor
Some more underside views:
And the finished look:
And in true Illinois fashion, it started raining as I took this shot.
Photoshoot cut short, the car headed back to be loaded for transport. Overall, this is truly enjoyable car that is a blast to drive and really takes advantage of a fresh setup that the owner can get the most from at this point in the build.
As mentioned at the start, getting a phenomenal new lease of life on a car like this doesn't have to be a 'start from scratch' approach when it comes to a full chassis. It can be foundation for the beginning of a long term build up over many years as time and budget allow, or it can be the start and end point of what would be a really solid, safe and performance-based project for many people out there.
