Closed Thread
Old 03-02-2015, 07:36 PM
ChevelleNV's Avatar
ChevelleNV ChevelleNV is offline
Default Chevrolet Zl1/CTSV Brembo Retrofit brake caliper Brackets
Item Location (City/State): Carson City, NV
Price: 175.00
Description:
Chevrolet Zl1/CTSV Brembo Retrofit front brake caliper Brackets $175.00 shipped via USPS priority mail
I engineered these for my car since I am running a 5th GEN IRS retrofitted to fit in the chassis and wanted to be able to run the stock ZL1 brakes all away around. and I figured there may be a few of you out there doing the same thing and figured I would make a few extra sets to sell.
For prototyping I used a RideTech dropped spindle (#11009300) and Wilwood 270-7037 hub, which is pretty standard for a
large number of vehicles. and based on my research should fit the following
67-69 Camaro, 67-74 Nova, 64-72 Chevelle.... and others, for spindle/hub fitment you can check Summit Racing's website http://www.summitracing.com/parts/ar...to?prefilter=1
These parts are Cad Designed and engineered, and waterjet cut from 5/8 6061-T6 aluminum. the design uses all three spindle bolt holes and also keeps dirt out from behind the hub. I have only a few sets, so first come first serve....
I will include mounting bolts for the caliper bracket.
You will need to re-drill the factory ZL1/CTSV rotors to the 5x4.750 bolt pattern.
if you are unable to re-drill them yourself I can re-drill them for you for 50.00 plus freight charges.
And to answer a few private messages I have received so everyone doesn't send me the same questions over and over.....
Q: Do you have a bracket that will fit this other style spindle?
A: No, as I stated in the ad this is for one particular application.
Q: Do you have a rear caliper bracket for a 12 bolt or 9 inch rear end?
A: No, I do not. and currently have no plans to build one at this time since I am running an IRS and this was designed to be ran on a car with the 5th gen IRS.
Q: Can you design me a bracket for such and such setup?
A: Not at this time....
Greg R.
LSX Concepts
Old 03-19-2015, 03:40 PM
ChevelleNV's Avatar
One set left....
Greg R.
LSX Concepts
Old 03-23-2015, 07:18 AM
ChevelleNV's Avatar
All of them are sold... but if there is enough interest I will consider running another group of brackets...
Greg R.
LSX Concepts
Closed Thread
