Old 03-22-2015, 11:51 AM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default 4L60E Trans Fittings for 1st Gen Camaro Swap
Can anyone tell me what they're using for transmission fittings? I was planning to use a 1/4 NPSM to -6AN at the transmission and then use a 90 degree AN fitting but the clearance at the shift tunnel looks a little tight. Was curious what others are running.
Chris
Old 03-23-2015, 09:17 AM
I'm looking in to Sweet performance and pure vision which both carry them.
they also have banjo fittings if you need more room.
http://www.ebay.com/sch/sweet_perfor...p2047675.l2562
Old 03-23-2015, 10:33 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I tried the AN fittings from Sweet for a 4L60E in a 69. They would not work without tunnel mods for clearance.
I ended up massaging the tunnel and re bending the OEM lines for clearance. I then used a compression AN adapter on the lines just forward of the firewall and ran braided stainless to the radiator.
Old 03-24-2015, 11:48 AM
ItDoRun's Avatar
That's my concern with using the 1/4"NPSM to -6AN adaptor screwed into the transmission. Then tying a 45 degree -6AN Female to -6AN hose adaptor to run to the cooler. The clearance looks awful tight but I don't have the fittings either. Maybe I'll just use the stock fittings and make two short lines and then tie stainless lines into that and run to the cooler. I don't want to modify the tunnel if I don't have to.
Chris
Old 03-24-2015, 03:11 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Your solution is here:
http://www.purechoicemotorsports.com...rod/prd371.htm
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
