Old 04-09-2015, 12:30 AM
HELLCAMINO HELLCAMINO is offline
Default What lugs to use (autocross)
I have been wondering since I run autocross quite often in my Elco and now my Chevelle if I should be using better lugs then I am right now? I have TSW wheels on both cars with hub centric rings. Have 3" 7/16 ARP wheel studs on the Elco and front of Chevelle, but 3" 1/2 studs in the rear. I am just using the 60 degree bulge acorn lugs. I have no problems as of yet, but know there are a vast variety of longer race lugs on the market and thinking I should upgrade?
Thoughts and ideas?
The ChevHeLLe
377 sb, 5 speed, 4:11's UMI Suspension
The HeLLcamino,357 sb, 700R4, 3:73's UMI Suspension
The Bad Weather Beater
Old 04-09-2015, 12:12 PM
Vince@Meanstreets's Avatar
As long as you are getting good thread engagement.
You can trim those studs down too.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 04-09-2015, 04:58 PM
Just don't forget to torque them and check em frequently!! I re torque mine frequently on the Mustang and many times I get movement (meaning they needed torquing).
Old 04-09-2015, 05:39 PM
Rod P's Avatar
Rod P Rod P is offline
I have heard your nuts are often loose
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 04-09-2015, 10:49 PM
That's what I figured. I torque to 100 ft lbs and recheck before every race.
The ChevHeLLe
Old 04-10-2015, 06:40 AM
Sieg's Avatar
Sieg Sieg is offline
Here's a little info from ARP:
ARP Wheel Studs - heat-treated 8740 chrome moly, tensile strength of 200,000 psi, sold in 4 or 5 packs, cadmium plated for extra durability, nuts not included
http://arpinstructions.com/generaltorque.html
