Closed Thread
Old 04-14-2015, 10:33 AM
jwcarguy jwcarguy is offline
Banned
Default 550hp LS2 6.0l Alum Engine W/ LS3 Topend
Item Location (City/State):Las Vegas
Price:
$4500
Description:
I am posting this for a friend of mine here in Las Vegas, please contact Jerry with any questions
I have a low mileage LS2 engine with 35k miles in it. The motor is a 6.0L LS2 bottom end( hd crank & connecting rods w/ floating pin pistons) with a LS3 top end (new GMPP cylinder heads and LS3 intake manifold setup).
I was building this motor for my 1969 Camaro, but changed directions and decided to use an LS7 instead. This motor would also be great in a sand rail or hot rod. Estimated crank hp is 550. It is a Gen IV motor with a 58X reluctor wheel.
It does not include a wiring harness, computer, fly wheel / Flex plate starter etc.
- The cylinder heads are brand new #823 castings from GM Performance Parts (part #12629063) and have the hollow sodium filled valves
- Comp Cam for rectangle port cyl heads specs: 229/236 dur 623/617 lift 112LSA
- 12 Point head studs
- GM MLS head gaskets
- PAT #8401 Dual "Gold" Valve springs kit with titanium retainers.
- Comp Cams Trunion upgrade on the Rockers
- .080" Wall 7.4L Chromoly Pushrods
- new GM LS7 Lifters & lifter trays
- Pistons have been fly cut on intake side for the cam
- New take off LS3 intake setup with LS3 42# fuel injectors & fuel rails and beauty cover
- New take off water pump
- Corvette balancer
- ARP harmonic Balancer bolt
- Corvette LS3 oil pan (center sump, shallow pan)
- Taylor spark plug wires
- LS3 coil pacs with harnesses & brackets
- LS2/3 vented pcv valley cover
- LS3 coolant steam port line
Asking $4500
Call / text/ pm Jerry " jovozx12 " (712)253-7583
note that the area code is 712 and not 702. I live in Vegas but still have an Iowa phone number.
Old 04-14-2015, 12:57 PM
Che70velle's Avatar
Great price on this fellas.
Thanks Dad!!
Old 04-14-2015, 01:02 PM
Banned
Thanks Scott!
You are correct, this is a great price, more power, better parts and cheaper than a LS3 crate engine!
I am running a similar engine (larger cam & TB) in my 68' Camaro and just built the same spec engine for Curtis' (SpiffaV8) 67' Camaro build
Great power and still maintain drivability
Old 04-14-2015, 05:29 PM
Novacaine's Avatar
Novacaine Novacaine is offline
Pm sent
Project Novacaine
Old 04-14-2015, 08:07 PM
Banned
Originally Posted by Novacaine View Post
Pm sent
pm replied
Old 04-15-2015, 07:15 AM
dwfastcam dwfastcam is offline
Great price, hopefully we will get it picked up Saturday for Project CashChunky.
Lifes a garden, you gotta dig it!
David Wright
1964 Chevelle Malibu Super Sport (Cinnamon)(Driver/Under Construction
!974 Nova Custom, Pro-Parts collecting stage
1972 Suzuki GT 380 Cafe' Project (Almost Done)
1969 Camaro, 355sbc, th-350, tubbed, slammed on Rallys, g-mod, Panhard bar,SOLD!
!968 Camaro, 355sbc, th-350, slammed on Rallys, SOLD!
Old 04-15-2015, 08:11 AM
jovozx12's Avatar
jovozx12 jovozx12 is offline
Default Ls2
Thanks Jeff for posting this for me! I have been really busy. I was planning on putting this motor in my 69 Camaro but came across a decent deal on an LS7 so I have changed directions a little. If anybody has any questions about the motor you can PM me or call/text.
Jerry
Old 04-17-2015, 06:11 PM
jovozx12's Avatar
Sold!
Jerry
Closed Thread
