Old 05-01-2015, 08:59 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default Need advice... buy new 9" or rebuild 12 bolt
So while tuning the car yesterday the shop blew up the 12 bolt stock rear end with pozie. I knew with 700hp it may not have lasted too long anyway so ..
Question is with my SpeedTech Torque arm rear suspension, do I drop $3200 on a new Speedtech 9" setup, or replace all the internals of my existing 12 bolt with some of the best parts money can buy ??
Or .. any other options ??
Thanks in advance
Cheers
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 05-01-2015, 12:37 PM
Vince@Meanstreets's Avatar
Thanks in advance
Cheers
Steve
If you have the Speedtech already, sell the 12bolt and go with the 9"
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 05-01-2015, 08:36 PM
Che70velle's Avatar
What actually broke in the unit? Carrier, gear set, axle shaft?
It's probably all junk now, if it scattered trash into the gear set at high rpm's, but can you determine the actual part that failed? If it's so bad that the caps are cracked, or even out of round, It's not worth fixing.
Thanks Dad!!
Old 05-02-2015, 04:10 AM
Sheck44's Avatar
Default rear end
Vince .. issue is 6 week wait from Roger, and with the sucky Can $$ this will end up costing $5000 ++
Looking into what actually broke .. will let you know
Cheers
Steve
73' FJ40 LS - SOLD
911 Hotrod - SOLD
2002 Gated 360
Old 05-02-2015, 06:55 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Cheers
Steve
Need to figure out what broke. Dynos are relatively easy on the rear end compared to banging gears on the street. Something may not have been right.
If the case is good you can sell it pretty easy and put the $ towards an F9.
You can go with Currie, Strange one of the others and install the Speedtech brackets and bolt it in.
Btw. I run F9s in all my cars
Old 05-02-2015, 01:09 PM
very true, its not like you are driving another mile to find a good place to pull over.
I bet its the pinion shaft or gear. which would be an easy fix.
Dealer for
NEVER FORGET -11
