Old 05-24-2015, 07:15 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Default Which Head Gaskets for LS3?
Maybe I should have titled the thread "Best Head Gaskets for Blown LS3"
I've done my initial sweep of the internet and found that the MLS gaskets from GM on the LS3 have been used up to 900 HP without failing.
However, I have also seen many recommendations being made for the LS9 head gaskets as well. Supposedly a straight swap.
Anyone here have an opinion on this?
D
Old 05-24-2015, 08:18 PM
Che70velle's Avatar
You'll likely get lots of opinions. The GM MLS stuff is great, and the ls9 units your looking at should be fine for your new purchase.
http://m.summitracing.com/parts/NAL-...leSwitchTablet
I must caution you however about you wanting to stud the bottom end. My ls2 is studded at the bottom, but I had my machinist line bore the mains with the new studs, because it will alter the main bore's roundness, due to a different clamping force caused by the main studs. Don't take my word for it, on this issue. Do some research. LS1Tech is your friend, or ask your engine builder.
Some people do it, and get away with it, and some not so much.
I'm not trying to talk you out of doing this, just throwing some caution your way.
I love your car, by the way!
Thanks Dad!!
Old 05-24-2015, 10:15 PM
DFRESH's Avatar
Thanks for the information Scott. I will do some additional research before I do anything on the main studs. Really appreciate it.
Doug
Old 05-25-2015, 08:27 AM
Just get hold of Tim McGilton at Kurt Urban.... ask them what they think. Todd is NOT your source of info on an LS motor...
http://kurturbanperformance.net/home/
Old 05-25-2015, 12:31 PM
Flash68's Avatar
Flash68 Flash68 is offline
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-25-2015, 02:02 PM
Watch your mouth old man. Get some steel head gaskets, just make sure you spray them with sealant.
Old 05-25-2015, 02:34 PM
DFRESH's Avatar
Rodger that GW----thanks for the contact at Kurt Urban.
XXX-OOO
D
Old 05-28-2015, 03:30 AM
71RS/SS396's Avatar
The GM gaskets are really good, we also use the fel-pro mls gaskets.
Old 05-28-2015, 09:08 PM
DFRESH's Avatar
Tim, thanks for the info----I went ahead with the LS9 gaskets after seeing your post and doing some additional research. I'm only shooting for about 700rwhp.
Doug
