Old 06-01-2015, 09:30 PM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default Heater hose reducer
Anyone know where I can purchase a metal heater hose reducer. 3/4 to 5/8. Found a plastic one, but a little nervous about "plastic" reliability.
Old 06-01-2015, 10:43 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Default fitting
Try this place
https://www.plumbingsupply.com/barb.html
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 06-03-2015, 07:20 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Instead buy a heater hose that is 5/8 with a 3/4 bell on one end
Napa 10084
Old 06-10-2015, 09:45 AM
DKz Garage's Avatar
Originally Posted by DEIGuy38 View Post
Napa 10084
Thanks guys.... I'll check it out. Now if I could just find a heater hose with a molded 45 degree bend on one end....
Old 06-11-2015, 08:28 PM
renegade6 renegade6 is offline
Try taking a look at the various hoses at the parts store. If you can't find that, try a Gates unicoil hose shaping coil. I used a unicoil on a previous project and it worked great.
63 Biscayne
Schwartz Performance Chassis
Build thread: https://lateral-g.net/forums/showthread.php4?t=37302
Old 06-11-2015, 08:57 PM
Musclerodz's Avatar
I can get them from Oreillys
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-14-2015, 05:18 PM
andrewb70's Avatar
Napa 10084
Thanks for this tip! I got that hose and it worked awesome.
Andrew
Old 06-14-2015, 05:29 PM
cpd004's Avatar
cpd004 cpd004 is offline
I've had good luck with Jags That Run:
http://jagsthatrun.com/Pages/Parts_C...-splicers.html
They have all kinds of unique stuff.
1971 Firebird
2017 SS
Old 06-15-2015, 01:54 PM
andrewb70's Avatar
I can second that. I use their radiator hose reducers/splicers when making custom hoses.
Andrew
Old 03-17-2016, 05:57 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
Napa 10084
Just to adding info as this is the one I bought instead of the Napa one
ACDelco# 18010L
GM# 88907450
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
