Old 11-19-2015, 09:20 PM
Default Temp sensor
Can a Temperature sender for a transmission be put in the cooling line close to the trans and get an accurate reading? I don't really want to drop the pan and put a fitting in it right now.
Old 11-20-2015, 05:51 AM
dontlifttoshift's Avatar
Yes, but the problem is that the probe on the end of the sensor takes up a lot of space. If your temp sender doesn't have a probe then it is easier.
That said, the pan is the best place for an automatic trans temp sensor.
Donny
Old 11-21-2015, 08:57 AM
Thanks Donny.
