12-12-2015, 04:47 AM
engine stand and lift
hey guys i am looking for suggestions on an engine stand and lift for my LS3. are the harbor freight ones decent enough? for the stand should i get 1000, 1250lb's? also and bolt kits or plates you guys recommend for lifting the motor?
12-12-2015, 09:04 AM
I would get the 2000# engine stand. I've used the 1000# and 1250# ones and when you try and move your motor around they feel like they're going to tip over. The 2000# ones are more money but better balanced and worth it.
Ahmad B
12-12-2015, 09:46 AM
Try Amazon.com, also centuryperformancecenter.com has a nice setup.
12-14-2015, 12:01 PM
The only thing I have purchased from Pep Boys was my Engine Stand - 5 Wheels, Gusseted, Folds up when not in use. It has never felt like it was going to tip over.
https://www.pepboys.com/product/details/9316487/01649
12-15-2015, 02:42 PM
Harbor Freight stand and hoist worked perfectly when I installed my iron block LQ9 into my 67. No point in spending big money if its not going to see much use. I would check your local Craigslist and see if anyone is selling one.
1967 Camaro - Project "Resale Red" - Sold to 175RGR
03-13-2016, 05:42 AM
I have both, and i've used the cherry picker many times to pull a fully loaded 351W, and TKO600 out of my Torino.
The engine stands are wobbly as stated. I have two models, the cheaper one has had a 302 on it for 4 years, it is freaky to move around. The one with the cross bar out front is not too bad.
Both engine stands came with the engines.
The cherry picker I bought used from a guy that only got it for a quick R&R.
Bottom line is the cheaper motor stand is scary, and I only use it for storage, rarely move it.
Joe
03-13-2016, 08:44 PM
i have 5 harbor freight stands i use at work, get the heavy weight one with 4 wheels and youll be fine, ive had one engine on the stand for almost 5 years and move it around every now and then, and i have no problems
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
05-29-2016, 02:35 PM
I like the gear drive eng. stand that started on Jeggs
http://www.jegs.com/i/JEGS-Performan...80059/10002/-1
, but IIRC, SUmmitRacing sells now too.
01-06-2017, 08:12 PM
look on Craigslist..... there are always some for sale (engine stand)
01-11-2017, 05:05 PM
Had my complete ls1 on a 4 wheel 1250 lb harbor frieght stand for a few years. Ls is nothing, I've had my pontiac and Buick motors on it as well. Those are big suckers.
