Old 12-14-2015, 11:52 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Default Bolt Size?
Anyone happen to have or know of a list that has all the bolt sizes used on the front end of a 67 Camaro? I plan on running stainless hardware and need the sizes so I can order everything.
Thanks!
Curtis
Old 12-14-2015, 12:07 PM
trevor572 trevor572 is offline
Default Hi Curtis.
Hi. NPD have a few master body hardware kits for gen 1 cars in stainless, different head styles etc. It gives a list of the areas it covers, does like trunk hinges and a bit of other stuff around the rear also. Cheers.
Old 12-14-2015, 12:30 PM
Spiffav8's Avatar
Lateral-g Moderator
Those are some nice kits, but....they don't fill my needs. I just need the sizes. There has to be a list somewhere.
Curtis
Old 12-14-2015, 01:51 PM
Default Hello Again.
I know I did buy a front hardware kit from Ricks that came with a list of what size bolts went where if memory serves me correct, I know it was still in the box with some left overs. I did send it with the car when Chris was doing the body and paint, I have got it at home again and I will check tonight to see if I still have that list there and get back to you mate. Cheers Trevor.
Old 12-14-2015, 05:51 PM
GTWayne GTWayne is offline
Default Camaro bolt sizes
I want to say ATK sells kits with a very detailed list of sizes for most autos.
Old 12-14-2015, 08:18 PM
Musclerodz's Avatar
There is not a "list" per say. What SS bolts are you planning to run? I can get you the basics for a count. Totally stainless makes a kit but it does not have things like the clips and nut plates you need as well which are not available in stainless. If your planning to run ring brothers, or rad rides bolt, its gonna get expensive quick.
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-14-2015, 10:49 PM
CarlC CarlC is offline
We're talking non-structural connections, right? In general stainless fasteners should not be used in structural applications.
http:www.vaporworx.com
Old 12-14-2015, 11:03 PM
Spiffav8's Avatar
Lateral-g Moderator
Yeah that would probably help if I was more specific.
Door Hinges, Front Sheet Metal, Hood Hinges, Fender Braces and the Trunk Hinges.
I plan to run 12pt stainless in all those places. I'll see if I can find a picture. Pretty sure you all get the idea now though.
These are from Chris Kinkers 69. Good example of the look I'm going for.
Curtis
Old 12-14-2015, 11:26 PM
Vince@Meanstreets's Avatar
Thanks!
we did ARP's on a 68.
5/16" x 18 x 1" fender/sheet metal
5/16" x 18 x 3/4" fender/wheel houses
5/16" x 18 nuts fender/header panel
3/8" x 16 x 2" fender to body
3/8" x 16 x 1" hood hinges
5/8" x 11 x 3" frame to body
3/4" x 10 x 1 1/2" bumper bracket
3/4" x 10 nuts bumper bracket
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-14-2015, 11:34 PM
Spiffav8's Avatar
Lateral-g Moderator
Vince! YOU ARE AWESOME! That's a good chunk of what I need.
THANK YOU!!!!!
Curtis
