Old 01-09-2016, 11:48 AM
Sieg's Avatar
Sieg Sieg is offline
Default Koenigsegg Freevalve
Without a doubt my favorite hypercar company..........
Major game changer:
Old 01-09-2016, 02:20 PM
Motobrewmaster's Avatar
Motobrewmaster Motobrewmaster is offline
very cool vid. When I was in engineering school discussing building engines.... over many beers ...cough cough 25 years ago. We talked about wishing you could use solenoids to control the valves.
You could then potentially change the timing and valve travel. This of course would ultimately be on a per cylinder basis. This means you could potentially make the engine run at a much larger power range and efficiency range.
Problem at the time and possibly currently was that the material tech wasn't there yet. Nor were the computers capable of processing at the required speeds.
This technology is the first steps to reach that goal. Obviously the computers have also advanced dramatically making that aspect most likely poissible too.
There is still some life left in the piston motor yet. So impressed by Koeningsegg!
Thanks for posting!
69 Camaro Owned since 1984.
Oh and Yes I am a Brewmaster.
Old 01-14-2016, 03:11 PM
z28cp z28cp is offline
Pretty sure Formula 1 already had or currently uses this tech.
