Old 07-14-2006, 03:44 PM
tomspo04 tomspo04 is offline
Default 502 RJ Engine Harness
Is there a trick to plugging in the injector connectors from the engine harness (initial install)? I thought I had it figured out...I spun the injector bodies around so that the plugs pointed up, but am not able to reinstall the injector retaining clips with the injectors in that position. Do they go in from the bottom? What a PITA! Thanks for any help.
Tom
1970 SS (L-34) Protouring Camaro, 502 RJ, TKO 600 W/aluminum drive shaft, 3.42 rear, C5 ZO6 brakes front & rear, Hotchkis TVS, Boze Mesh; (17X9.5 275-40) & (17X11 315-35), Rick SS fuel tank W/pump, March Ultra serpentine setup, Hiedts/GW UCA's & LCA's, MagnaFlo 3" SS exhaust w'Xpipe.
Old 07-14-2006, 04:26 PM
rockdogz's Avatar
rockdogz rockdogz is offline
I had the same question initially but spinning the injectors around so that the connector pointed up made it easy to plug them all in.
-Tom
camarorestoration.com
Old 07-14-2006, 07:18 PM
Tom, So did you leave the retainer clips off? That's what I ended up doing...will have to see if they leave once I run it.
