Old 03-13-2016, 10:43 AM
akrapovic's Avatar
akrapovic akrapovic is offline
Default Vintage air trouble shooting
Hey guys, I'm at the point in my a/c install where i was checking function. I have a vintage 3 knob billet controller which powers up and will change fan speed. The problem is i can't feel air at the defrost or upper vents. I'm almost thinking the vent blend door is stuck, or the controller is bad. Anybody have a similar experience?
Old 03-13-2016, 02:12 PM
130fe 130fe is offline
Thumbs up
There is a calibration procedure for the controllers that you might have to go through so the AC control module will learn the upper/lower limits of the controls. I couldn't find it on line, but a quick call to their tech line will get you the info you need. Basically, you have to ground the gray wire (by the relays) in a certain sequence while moving the controller knobs. Only takes about a minute to do.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 03-13-2016, 08:17 PM
akrapovic's Avatar
Thanks, i will give them a call. Hopefully this solves my problem.
Old 03-15-2016, 02:57 PM
akrapovic's Avatar
Tech department went over the wiring with me. Got it figured out
Old 03-18-2016, 04:53 PM
Riddler's Avatar
Riddler Riddler is offline
What was the issue to help future people that search. I know I'll be installing VA soon.
Thanks,
Riddler
