Old 05-18-2016, 04:34 PM
eversmann79 eversmann79 is offline
Default Suspension Dilemma for my car.
Hi all, I am trying to gain some insight.
I own a 69 camaro that is currently under the knife getting some upgrades. My dilemma is, the speedtech pro touring subframe is only 4599 now. I already have the tall ATS spindles. Now I can afford the new subframe but it is really worth the extra money over just getting the speedtech arms and sway bar? I really would like to run a 275 tire up front to offset the 335 in the rear but I am just trying to get some reviews of the speedtech subframe complete vs stock subframe with tubular geometry corrected parts. Thank you all.
Keith
Keith
69' Camaro "Nellie"
ATS spindles, GW arms, QA1 coil overs up front, Bilstein in rear DSE rear leafs, 18' Summit Legend wheels 245/40 fronts 275/40 NT05's.
Hopefully soon to be minitubbed and lsx swapped
Old 05-18-2016, 06:24 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
Are you going hardcover race car or just weekend warrior? I am doing stock sub welded seams with the full GT package. Should be more than enough for spirited driving.
Old 05-18-2016, 07:13 PM
its a weekend warrior that wants to run with my friends c6
Keith
69' Camaro "Nellie"
Old 05-18-2016, 09:22 PM
98ssnova's Avatar
Weld the frame up. Get this http://www.speedtechperformance.com/...rod/prd260.htm
Have them add this
https://lateral-g.net/forums/showthread.php4?t=52424
Boom install and your done!
Old 05-19-2016, 09:19 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
A lot depends on your budget.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 05-19-2016, 09:29 PM
98ssnova's Avatar
Steve I assume his budget is at least 4500 since he wants the complete subframe. Check his OP. If Speedtech is his company of choice the links I gave him are his best option for complete suspension on his budget?
Old 05-19-2016, 10:09 PM
98ssnova's Avatar
Old 05-20-2016, 05:24 AM
Che70velle's Avatar
OP wants to run a 275 up front. Not impossible, but tough to do with stock frame, and is very expensive.
I'd say new subframe...
Thanks Dad!!
Old 05-20-2016, 07:48 AM
Yes I can get the subframe, it is currently in my budget but didn't know how much better the subframe actually is over just arms and bolt on suspension
Keith
69' Camaro "Nellie"
Old 05-20-2016, 08:51 AM
Blake Foster's Avatar
Don't take our word for it
http://www.speedtechperformance.com/...rod/prd500.htm
See what Mary had to say.
this Nova has the GT package mentioned above with the addition of the Rack And pinion,
since you have the ATS spindles, (if they are the tall ones) we would swap the standard upper control arms for the high clearance ones and then a 275 will be no problem on a 8,5 or 9" rim. you may loose some turning when the tire touches the frame on the back side.
The biggest advantage of the subframe is the coil over combo and the improved motion ratio, tire clearance. weight, strength, looks, and if your sub is bent or rusted.
we can upgrade to the Chicane weld in coil over set up as well.
http://www.speedtechperformance.com/...prod/prd12.htm
Blake Foster
